rusty_pole
ParticipantRe: drum pulley
hey guys,
thanks for all your help….I’ve been sent the correct link for my bosch and its been order via the ukwhiteappliance shop
thanks again!
Rusty
rusty_pole
ParticipantRe: Bosch WFF 2000 – Stiff Drum but still turns
thanks for your help
the full machine model is:
Bosch WFF2000GB/12thanks again
rusty_pole
hey,
i need a new drum pulley wheel….where can i get one?
can’t see the part on ukwhitegoodsthank alot
rusty
rusty_pole
hey,
thanks for the advice so far…
no that the sun is on its way down i’ve stripped the washing machine and quickly found a problem. The large wheel that causes the drum to turn by the drive belt is wobbling badly.
I have taken the drive belt off, its fine and no damage here.
I have take the large bolt out of the middle of the wheel which has exposes the inter-meshing teeth between it (the drive wheel) and the centre pin of the drum.
The teeth on the drum side look fine and appear undamaged.
The teeth on the large wheel are almost completey gone, the metal almost smooth.I hoping a replacement wheel will sort the problem out but don’t know the name of the part or when to get it.
I looked online and none of the usual places have a picture of the part i need. It basically a large silver wheel that connects to the drum and as the drive belt running around it.hope you guys can help
cheers
