September 25, 2023 at 6:55 am in reply to: Samsung WF80F5E0W4W shuts off mid wash and buttons not responsive #488145
rusty_u
ParticipantThanks for the confirmation, will sort a replacement.
rusty_u
ParticipantRe: Ariston A1636 Fubar’d
Forgot to update this, was indeed all down to wiring thankfully.
I notice there is a replacement harness available, so can’t be too uncommon. Will be treating it to a new door seal now, as the original one is a bit rank 😆
rusty_u
OK, fixed the wire, and have a new error. I now have the 3rd button lighting along with the lock LED.
Now the motor does move the drum when you start a cycle, but only about 1/4 of a turn in each direction?
rusty_u
I have discovered a broken wire on the plug that connects to the motors loom, I feel this is a strong candidate for causing my problem!
Annoyingly it’s broken flush with the plug, so I’m going to have to split it, I think.
rusty_u
ParticipantI was under the impression that being a 3 phase motor, it didn’t have any brushes?
Might have got the wrong end of the stick somewhere though.
rusty_u
Didn’t notice anything obviously visually wrong when I was getting the control board out, but didn’t really stare too much.
Multimeter time it is then 8)
rusty_u
ParticipantWhat I mean is it’s the 4th light which is also the bottom one 😆
Don’t suppose there is any way to test the motor?
rusty_u
ParticipantWell it’s half way through it’s first cycle after I dislodged the horrific goo from inside the pipe, and I am pleased to say that it is scorching hot inside again (put it on the hottest cycle, an acid test if you will)
Thank you very much, I guess I shall be making semi-regular checks on that.
I’ve also noticed that it sounds different now, it used to make a kind of KERPLUNKâ„¢ repeatedly at the start of the cycle, and at points during it, that’s now gone.
rusty_u
ParticipantRe: Bosch Logixx Automiatic SGS0902GB/04 Fault(s)
Great advise, that pipe is funked up beyond belief and (according to my tap) severely restricted. Will clean and refit tomorrow. While the lower panel is off, is there anything else worth doing/cleaning? Might as well do some good old preventative maintenance if possible!
Thanks very much for your help
rusty_u
Right a small update:
I am pretty sure that when it takes forever to complete it’s cycle (as per fault #2) it isn’t heating the water, as stuff is (eventually) coming out wet and not as clean as it should be.
rusty_u
Seems too, or at least it does some of the time, it ran all right last night, at the second time of asking (first time fault #1 reared it’s head).
I can make a little addition to #1 as well; the machine isn’t totally silent, it makes a few noises as per normal, then falls silent and does nothing.
