Ryoken_1972
Participantagain thanks for the reply , i put it on a 30 minute wash, after a bit i opened the door and the water was hot, all though i did notice a weird rythmic noise coming from the bottom of the machine. (sounded like slurping so i suppose thats normal, just never heard it before) , but that could just be me , and the machine did a full cycle no probs. one thing i noticed was the smart meter we got went from
415 watts to 2246 watts while the dish washer was heating , but then the kettle only throws it to 3000, strange what you dont notice, so i think the heaters ok
steveRyoken_1972
Participantjust looked under the sink, there are two pipes, one goes from the cold water pipe, and another one to the sink drain off, so its cold water only,
the 30 minute “rapide cycle is the quickest , ill put it on this cycle and open the door after 20 mins, if its hot inside then the heaters heating the water.
but again it could be a failing unit not a terminal one?.Ryoken_1972
Participantthanks again for the reply, wife says that, its not a 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} issue it might be ok for a few times then put on the errors, so its a bit intermittent. is there a nailed on test i could try, , just looked and a brand new motor heater element is 40 quid ish , cheers again
Steve -
