secret-squirrel
  • in reply to: Indesit Washing Machine Model WIE 147 #202506
    secret-squirrel
    Re: Indesit Washing Machine Model WIE 147- Update
    I contacted Indesit regarding this error, but things have taken a turn for the worse!! switched the machine on Yesterday, display just shows random numbers when any button pressed. Assume now this must be an electronic problem with either the display / button board (Behind front panel) This also seems to have a chip installed on the board. This could also be the main PCB located at the bottom of the machine. Anyone have any ideas about this one.
    Many Thanks
    Secret Squirrel
    in reply to: Indesit Washing Machine Model WIE 147 #202505
    secret-squirrel
    Have checked the door, and all appears to be in order. Door Locks correctly, and cannot be opened with machine running. Any other Ideas anyone?? So glad I found this forum. Many thanks for your help so far.
    Secret squirrel
    in reply to: Indesit Washing Machine Model WIE 147 #202504
    secret-squirrel
    Thanks for your reply.
    The error code that comes up for the Door is usually “DOOR” I am getting “DENO” can you just confirm this is the door. Can the door cause more than one error??. I Have seen the door code, and this is mentioned in the instruction book for the machine.
    Door appears to work correctly and locks when the lock light comes on, but will have another look.
    secret-squirrel
