Re: Fisher & Paykel GW712 – overfills &/or won’t start cycle
Hubby said he thought it was either the pressure sensor (water level sensor) that the water level tube attaches to which is mounted to the motor controller card, or the motor controller card itself.
He thought more likely the motor controller card because would assume that if the water level sensor was faulty, it would not fill to correct level in manual mode, but it does.
Doesn’t believe it could be the out of balance sensor switch as when it is manually advanced to spin cycle via the advance button, it empties and spins as it should.
Just bought a new motor controller card & fitted it & it’s doing the same thing. 🙁
Any ideas PLEASE?
