shiny_shark
ParticipantRe: Bosch WFO2464GB Drum Not Turning
Thanks for your reply Penguin45. I’ve had a good look at both of those articles & while I think we could manage the brushes, I’m not at all confident about changing drum bearings – are they difficult to do on these Bosch machines? We have only a basic level of DIY as far as these things are concerned.
Is this likely to be an expensive job if I call out an engineer? It sounds like it would take a lot of time which is where I expect it would get pricey.
The machine has been well looked after but I have had it about 6-7 years & use it a lot (2 washes most days). Is this an acceptable life for one of these machines?
Thanks again for all your help,
shiny_shark 🙂
shiny_shark
Thanks for your reply.
The noise the machine has been making happens when the drum is turning during the wash part of the cycle & also especially when it is spinning. It sounds like a metal grinding on metal type of noise. It’s very hard to describe now I can’t listen to it!
We can try to look at the brushes this weekend but are not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure what they look like! Is there anywhere I can find a photo of what the brushes look like?
Thanks again 🙂
shiny_shark
