Simon E
ParticipantRe: Smeg A1-6 range cooker
Hi K… I have just received the safety thermostat from Dave. I used my initiative to fit it as he did not have a technical drawing (but I am guessing there is only one safety thermostat?). Unfortunately the oven is still not working. When I turn the oven on and turn up the thermostat, the temperature red light does not come on. Does this help diagnose the fault? Rgds S
Simon E
Many thanks K, you have been very helpful. I will do as you suggest. Even if it does not work I like to have a go at these sort of jobs. A big thank you for pointing me in the right direction. I maybe a few days before I do the job (as I’m away later in the week) but I will let you know how I get on when I’ve done it. Kind regards, S
Simon E
Hi Kwatt.
I had a look at this cooker this evening: The terminal blocks all look good and clean and the oven timer seems to be working (it resets ok). I think testing the safety thermostat is beyond me ( I am not even sure where it is… but I guess it is somewhere behind the front control panel?). I think I am capable of replacing a thermostat if you think it is the next thing to try? if so can you supply the part?Simon E
Many thanks, I will have a look later and let you know how I get on. S
