Simon__NZ
  • in reply to: F&P Smartdrive GW508 – Pump always on & won’t fill w #160661
    Simon__NZ
    Re: F&P Smartdrive GW508 – Pump always on & won’t fi
    Many thanks for that Penguin.
    Is the Motor Control Board something I can replace, and if so, can you please suggest where I could obtain one?
    Where do I locate the Motor Control Board please, and what tests do I conduct to see if it needs replacing? Sorry, new at this.
    Thanks again.
    Cheers
    Simon
    in reply to: F&P Smartdrive GW508 – Pump always on & won’t fill w #160659
    Simon__NZ
    F&P Smartdrive GW508 – Pump always on – Correction
    I have a correction to the Code I supplied in my original message.
    I had not used the “..advance once & spin speed up…until Hold & Slow etc…”
    When I now do that, the lights, from left to right show 00001101
    If I have figured your binary codes out correctly, that makes an error code 13?
    If I read them from right to left, I get 10110000 which makes an error code of 176??
    I wonder if it relates to the OOB (Out Of Balance) Switch, as the washer was overloaded & unbalanced when the fault first arose?
    Thanks in anticipation.
