Re: Faulty Smeg Dishwasher
clivejameson wrote:9 times out of 10 its a food blockage in the transfer pipe between the metering tank and the sump. You can do a DIY which will almost certainly clear it….lift out the filter in the base and at about the one o’clock position in the sump
Clive
| have a DWD61SS – This worked for me but only after I had changed the timer. When it first started playing up, it appearded as if the timer wasn’t advancing. After changing worked OK until dishwasher was refitted.
Fingers crossed, following the cleanout it has worked faultlessly for three washes and has now been refitted.
Go for the easiest (and cheapest) options first !!
