Ste.eir
ParticipantMicroswitch auto correct lol
Ste.eir
ParticipantHi Dave model number is DWD5414S checked the microsurgery in the base and that checks out ok, just don’t get a neutral to the fill valve but I am getting a live, haven’t had any luck finding a wiring diagram
Ste.eir
ParticipantDoor switch checked and is ok, im thinking fault is on wiring harness from pcb to fill valve, nothing else holding it out, do you know if these mahines break the neutral,i have 220v to fill valve but no neutral,jumped a neutral and valve energises but obv keeps filling and consequently draining down now,
Ste.eir
ParticipantHi dave not checked but when start program it does drain first so im assuming it would not if door switch was faulty, i have replaced pcb and flow counter also.hitting a brick wall now
Ste.eir
ParticipantDoes it get down to temp then cut out and not come back on or just run until it stops, could be compressor overheating tripping thermal overload on it
January 12, 2019 at 11:57 pm in reply to: AEG – Warm Fridge / Freezer Ok: Help with problem diagnosis please! #459557Ste.eir
ParticipantSounds like your fridge is going low on refrigerant,(gas)first symptom is freezer box temp ok and fridge box getting warmer, freezer now starting to warm up, not enough gas to sustain the fridge box would need to attach guages to low side and check pressures, find and repair leak.
