Hi Dave, the ntc that sits next to the other stat is reading 14.2 k ohms @ 20 degrees. And the ntc that sits in the fan housing is reading 13.6 k ohms @ 20 degrees. Does that sound about normal ? Thanks
The problem I’m having is the “clean filter” light is coming on half way through the cycle when both filters are clean (and all internal air ways) yet if I run the machine with the door open it works perfectly?
