Swn-Y-Mor
ParticipantRe: Zanissi ZWK 1430s – E20 error
Took the filter off – got soaked in the process – filter clogged with about £1.75 in loose change and fluff/gunk
Cleaned the filter and it is now working like a dream.
Thank you for taking the time to reply. What a brilliant resource this forum is – THANKS 😀Swn-Y-Mor
ParticipantRe: Diplomat ADP8322 Error Code 4
Any other suggestions?
Swn-Y-Mor
Arghhhhhhhhh……….. 😳
45 mins in it starts beeping. I open the door and the beeps get much much faster (not much of a gap between beeps)
Light flashes 4 times againBack to the drawing board
Swn-Y-Mor
After difficulty getting integrated dishwasher out of housing, and removing side and bottom coverplates, I finally removed that black plastic grid thingy. It was a bit gunged up. Strugglked to put everything back together. Bleeding knuckles too
The dishwasher is about 30 mins into its cycle, and no beeps yet. I hope I’m not too premature here…. 🙂
Swn-Y-Mor
gegsy wrote:Hi
Either the machine can’t empty or the WI (water Indicator, 3 oclock position below filters) is clogged up or faulty.
At worst it could be the PCB module. 😥Power off if you are to investigate :plug:
Thanks for your reply. Is the Water Indicator removable? to unblock?
I have checked that bottle traps under sink, and all spigots and pipes are clear. There is water sitting in the sump where the filter sits. Is this normal? -
