The Moo
  • in reply to: Zanussi TDS382W Front Drum Felt Gasket Replacement #353465
    The Moo
    Re: Zanussi TDS382W Front Drum Felt Gasket Replacement
    Thanks again Martin. Much appreciated! 😀
    in reply to: Zanussi TDS382W Front Drum Felt Gasket Replacement #353463
    The Moo
    Thanks for the advice Martin.
    Can you advise if the failure of the felt gasket is likley to mean that there may be a problem brewing else where, e.g drum bearings on the way out, or do the felt gaskets just wear out over time?
    Thanks again!
