The Skeptic
Viewing 1 post (of 1 total)
  • in reply to: Hoover HNL662-80 programmer fault ? #427530
    The Skeptic
    Re: Hoover HNL662-80 programmer fault ?
    Having played with another almost identical machine and control panel, I have now worked it out.
    In order to get the machine to run through its diagnostic procedure or produce the fault codes on these machines, you press and hold the left hand option button which has an LED, turn the control knob clockwise 2 clicks. Keep holding the button for a further 5+ seconds and then, when you release it, all the lights come on and the test procedure starts.
    Unfortunately, on the machine in question, nothing happens. I have checked all the connections so must assume that it is the control panel which is at fault.
