tight fisted
ParticipantRe: Stoves 900EF oven- how do I get the clock knobs off?
O.k. managed to get knobs off and pretty sure my problem is the energy regulator (grill control). On it is a number 33ER9MHT. Looks like these are more rare than rocking horse poo. Is there an alternative please?
tight fisted
ParticipantRe: Whirlpool ADG 644 1X flashing 4.
So we thought it was about time to call in a repair man.
He walked into the kitchen, went up to the dishwasher, pressed in the control button for 5 seconds and walked out with my cheque.
tight fisted
Thank you. Will do.
tight fisted
O.k. let’s see if I’ve got this.
There is no indication the m/c. is trying to drain so the water level indicator is not the problem. But the flashing occurs as soon as the start switch is pressed, there is no water in the sump, the pump isn’t pumping but has no water to pump out anyway?
tight fisted
ParticipantRe: Whirlpool with green light flashing
Many thanks Penguin 45. The state of things at the moment are :- there is no water in the sump. When the start button is pressed there appears no response at all and the green light starts to flash within a couple of seconds.
tight fisted
Anyone know where I can learn to count? Flashing 4 not 7. So reading other threads took off pump and drained sump. Now, whilst I was wandering around down there I noticed that the rear part of the big clear container, is it the monoblock, looked full of gunge. Disconnected top pipe but made no difference. Where do I go from here?
