Tim Pickard
  • in reply to: Ise10 problem #450876
    Tim Pickard
    Re: Ise10 problem
    Pump is fine it seams to be an electronic fault but could it be a problem with the controls or main board
    in reply to: Ise10 problem #450874
    Tim Pickard
    Re: Ise10 problem
    The model number of the washing machine is ISE 10 1607W.
    Serial number104310944559. Type WM 70.1
    I have also used a washing machine cleaning liquid to make sure all the pipes are ok.
    No matter which program I choose it will have a blip when it comes to the spin, it doesn’t have to be the last spin it can be an intermediate one then the machine is stuck. The only way to change or move the program is to turn it off then on again. Let it drain then open the door
    in reply to: Ise10 problem #450873
    Tim Pickard
    Re: Ise10 problem
    Pump filter ok no fault codes ,it’s an intermittent fault .i have 2 main circuit boards and same fault accures when they are swapped
