Trojan Hussar
  • in reply to: Hotpoint FDL570P.R cannot locate error code. #434898
    Trojan Hussar
    Re: Hotpoint FDL570P.R cannot locate error code.
    Salt/Rinse Aid and the Wash/Drying/End all flash. I was a bit concerned that the drain pump runs continuously even after the machine is empty, which I would assume isn’t that great for an impeller.
    in reply to: Hotpoint FDL570P.R cannot locate error code. #434896
    Trojan Hussar
    Having just coughed up £30 for a replacement water turbine, it arrived today and I’ve just fitted it. Unfortunately it’s made no difference whatsoever.
    When you start a cycle it does a quick drain, pauses and then starts taking on water for a few seconds before flashing all the lights and draining itself.
    in reply to: Hotpoint FDL570P.R cannot locate error code. #434894
    Trojan Hussar
    It did a couple of washes, so I put the side panels back on and then of course it promptly stopped working again. It now fills with water panics, flashes the lights and continuously empties.
    in reply to: Hotpoint FDL570P.R cannot locate error code. #434893
    Trojan Hussar
    Thanks for the info, I’ve removed the turbine unit, it’s all nice and clean and the turbine spins freely so I reconnected it. I set the dishwasher to speed wash and it has taken on water and started the first cycle so fingers crossed.
    Thanks,
    Jason.
