tyre_tread
Viewing 1 post (of 1 total)
  • in reply to: bosch dishwasher no water #247379
    tyre_tread
    Re: bosch dishwasher no water
    I Have a similar pproblem, i.e. no water enters the machine but possibly a different reason.
    The pump seems to operate continuosly and the programme does not seem to advance. Is this likely to be the programmer or the water level monitoring mech.
    I have removed the top and side panel and cleaned out the plastic multitube with the little valve in that seems to control the water flow and this makes no difference.
    If I operate the wate inlet microswitch manually then the machine will fill but as soon as I release the switch the pump just empties the machine again and continues to run.
    All help is gratefully received
