user_50630
  • in reply to: Idesit DIF04b1 #430731
    user_50630
    Re: Idesit DIF04b1
    I have run two cleaners through the machine, cleaned limescale from the door seals, checked wiring loom underneath (feels dry).
    I have upped the water hardness and rinse aid setting to 3.
    Dishwasher failed on Program 4 and switched itself off…but then it completed without error the intensive wash program.
    It will not do the test cycle.
    Its £110 for a ‘one time’ fix, or £15 per month for an unlimited fix or £220 for an identical replacement…I will keep going with it…but a new one seems the most sensible choice!
    in reply to: Idesit DIF04b1 #430730
    user_50630
    Re: Idesit DIF04b1
    It has just completed a wash without error. I am thinking the PCB may be getting wet/damp
    I have never liked this machine….had to get a new dinner service because it cant take an adult size plate
    I have my eyes on a Bosch!!
    Thank you so much for your help, really appreciated
    Regards
    Matt
    in reply to: Idesit DIF04b1 #430728
    user_50630
    Re: Idesit DIF04b1
    1. Open the door and switch on CHECK
    2. Switch off CHECK
    3. Press and Hold ‘P’ machine beeps CHECK
    4. Switch on ON BUTTON FLASHES ….LIGHTS ONE TWO AND THREE ON SOLID….LIGHT FOUR FLASHING…..ALL LIGHTS COME ON SOLID….TWO BEEPS….MACHINE POWERS OFF….SHUT DOOR….NOTHING ELSE HAPPENS
    in reply to: Idesit DIF04b1 #430727
    user_50630
    Re: Idesit DIF04b1
    Thanks, will try it now and report back.
    in reply to: Idesit DIF04b1 #430725
    user_50630
    Re: Idesit DIF04b1
    When it starts beeping, with the door still closed I can see all the lights are flashing, but when I open the door, there are no lights flashing. When I close the door the cycle resumes but the beeping continues.
