Warren C
  • in reply to: Hoover AXI washing Machine #473464
    Warren C
    Warren C wrote:
    Thanks will try that now and will let you know 🙂
    OK, so i turned the washing off, turned back on, set a spin & pump cycle, and its drained fine? I check the pipe and the drain inlet, and both where ok.
    So unsure now why E22 has occurred on two wash cycles now?
    in reply to: Hoover AXI washing Machine #473463
    Warren C
    don wrote:Hoover E22 is generically a draining issue, “recently purchased” check installation of waste hose and check filter are the first ports of call.
    Don
