Re: Fagor FU-6116IT help
Thanks for the reply
I think i may have cracked the heater fault, i noticed there was power to the temp switch but not after it. When i removed it there was a little ‘switch’ holding the contacts open. ive reset it and now have mains on the element and a hot glass on the drum door 😀
as for the groaning i noticed there were signs of sand around the drain motor assembly.
Maybe sand has got in there an intermittently causing this noise, it does seem to happen sometimes during draining.
Thanks Will
