AEG model T59870 dryer needs two turns to dry clothes
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum AEG model T59870 dryer needs two turns to dry clothes
Viewing 14 posts - 46 through 59 (of 59 total)
  • #477947
    Haramo
    electrofix wrote:well belt could be slipping so low air flow
    part no 1361007006
    https://shop.aeg.co.uk/laundry/tumbl…t/p/1361007006
    the fluff in the heat exchange does not look that bad. Your dryer does not have a heater as its a heat pump system
    Dave ok, replacing the belt can helpt to give more power tot the fan. will do this first then.
    and about cleaning the dus of he heating element, I maybe used to wrong term, but I mean the parts that are fixed and cannot be taken out. in service manual it’s called: capacitor and steamer or Condenser and vaporizer.
    #477948
    Haramo
    electrofix wrote:and the graph shows expected temperatures at 4 points over time. you would need to measure these temps and compare it to the expected reading
    bear in mind though if its not to spec you cant fix it
    Dave, so this means that if the belt does not solve the issue, then it’s best to buy a new one? to recharing gas is not possible? by a technician? hmm but replacing base completely , then it’s best to buy a new dryer.. . Will post a new thread which one is best to buy if needed.
    #477949
    this is going to be an ongoing problem with dryers in general. since its no longer a dryer as we know it, and uses fridge technology to save energy, then the fridge side can only be repaired by a qualified fridge engineer, with all the proper tools etc. The unit works more like a dehumidifier and could be replaced by a dehumidifier, a table fan and a rack but you would need a spare room
    don’t forget if it does not work efficiently then it could be lack of gas or compressor failure and a fridge engineer would have to take pressure reading to determine
    Haramo
    I ordered the new original belt .
    The clothes are getting more difficult to dry , whole day and very wet. . And I found a lot of water in the bottom filter , I took the water out. Even at the door , once opened , I see condens on the surface and water in a space from the filter in front of the trum.
    should I check the water pump too ? Of first replace the belt from the van ?
    #477951
    i would change belt first and get better air flow
    dave
    #477952
    Haramo
    electrofix wrote:i would change belt first and get better air flow
    dave
    Dear Dave
    first of all, my sincere apologies, as I really neglected the dryer due to workload and familly.
    today my first free day after so long time, I decides to continue to try to fix the dryer.
    yes we used the old way to dry our clothes, but this method , gives a lot dust on the clothes. It does has an advantage: less use of eletricity, first time we received some money back from the gas and electrick company :-).
    Before I stopped, I did changed the belt that is connected to the fan. but same issue.
    Today I took out the waterpump , that mathces the one that you showed me:
    https://shop.ukwhitegoods.co.uk/d422207-compatible-tumble-dryer-water-pump
    But only difference: mine shows 5 Watt, the on thelink 10 Watt.
    or is is save even if the Wattage is higer?
    Wel let’s hope this will solve it I think it will be my last replacement.
    what is left is to check the brushes , but normally they are ok, or as a last to let a technician fill in the gas (summarizing all that was discussed in this forum).
    #477953
    if the pump is a problem then the water will build up until the full water sign comes on; if that is not the problem then its not the pump
    Haramo
    Dear Dave
    see message you send number 8 why try to replace the waterpump.
    I don’t use the high tank water as the water goes directly to te house water … .
    So I think the water sign will never led up?
    I received today the new waterpump, hope to continue end of the week.. .
    #477955
    machine will not gravity drain so still needs the pump
    had one yesterday with similar problems. when i removed the pump it started working and pumped out the water. have now left it to see if it fails again
    Haramo
    Dear I replected just now the water pump. I wanted to close all but then I saw:
    see picture (pulley is touching the white plastic of the motor)
    https://www.dropbox.com/t/vkXMuZ64DncyPYkM
    I remember I had to remove all that was to see , as it was part of the old pully (quote Dave: make sure all residue of the old pulley has gone, see message #3 thread Main motor pulley not sure if this piece is part of it and # 13. ).
    maybe I can put that item back in it’s place? Hope I can find it. after removing the plastic arround is it’s little ring. (iron?)
    #477957
    Haramo
    see picture of the ring, don’t think it’s iron but it’s firm from inside
    https://www.dropbox.com/t/RCsAyFSZpQICWdYs
    #477958
    try moving the belt to the last groove on the motor ans the pulley should follow
    Haramo
    Will give it a try , I alreay started a test, after I tested the tumble , the pulley does not come near the plastic of the motor.
    You mean: belt to te last groove on the pulley? there is not belt on motor.
    #477960
    the pulley is a crown pulley so belt will self centre
    so will move on the shaft to get in line with the motor shaft
