AEG model T59870 dryer needs two turns to dry clothes
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum AEG model T59870 dryer needs two turns to dry clothes
Viewing 15 posts - 1 through 15 (of 59 total)
  • #99800
    Haramo
    We have a AEG model T59870
    Type P502867 tumble dryer. Prod no: 916 096 618 00
    I ‘m not sure if somethign went wrong, after replacing motor pulley and tumble belt.
    I opened the dryer once again to see if somethings wrong: tumble belt is firm and on its place, motor pulley is showing something as if it’s getting pieces away from if , bit by bit.
    and an item almost touching the Tumble, I pushed it a little bit to the tumble then it has contact, I pushed it back, but have the feeling that it will keep making contact if the dryer is active.
    See pictures dropbox link to show you the motor pulley how it looks like after two weeks use. the belt is correct installed.
    https://www.dropbox.com/t/f9c5JSu9FjhOjG0b
    #477903
    was this a genuine pulley as it looks a bit ropey
    Haramo
    I’m from Belguim, I found it online from a Dutch (The nederlands, our neigbours) online shop:
    https://www.partsnl.nl/zanussi-onderdelen/zanussi-spanrol-1250125034-wasdroger
    It should be a original one, … .
    So I should send them the picture?
    or can it be that something else causes this ?
    #477905
    i cant think of anything that will cause it
    does look like its gen but cant read the language very well
    AEG and spares should be here somewhere
    https://shop.aeg.be/nl/
    Haramo
    Google translate ?
    i took the motor pulley out and put it back in but In reverse . I notitced that the one end is not the same as the other end . No I thing there will be no plastic everywhere . After test I will no if it’s fixed.
    #477907
    see how it goes
    Haramo
    Dear
    the clothes are still not completely dry.
    and when the dryer finishes, there is a noise, this time it was higher and I recored it.
    see dropbox link as I’m not allowed to upload aiff files.
    https://www.dropbox.com/t/Y8X7gS045fh6qCXv
    #477909
    if i read it correctly then this noise is there when the drum is stationary
    if yes it will very likely be the pump
    Haramo
    Stationary = drum stopped
    if I understood correctly then yes this noise only to hear at the end when drying is finished . Not always .
    Could you send a link to this part ?
    #477911
    Haramo
    Thanks .
    what is the function of this pump ? Can it cause the issue ( not drying good )I have ?
    I have seen many names of pump : heat pump , condens pump , water supply pump, I want to know if one of these is the same as the one in the link.
    #477913
    that pump pumps the water into the draw at the top. they can make a heck of a noise somtimes when they go wrong
    heat pump is what does the drying. think of this dryer more like a dehumidifier in a case
    Haramo
    Ok thanks . So the waterpump needs to be replaced so the water can leave. We don’t use the draw but directly F to the drain , i read again the user manual , the tube that goes to the drain must not be to long , I never Cut the tube . Should this be a cause then I can cut it . As the drain is behind the dryer. Not even a 10 cm.
    i also took some time to watch videos and started to clean : don’t know the name, see photo :
    https://www.dropbox.com/s/igp7g7brd9clliz/How_to_clean_IMG_8491.JPG?dl=0
    om the videos they could take it out and wash it . Mine is full with dust and don’t know how to disassemble this part , any help ?
    #477915
    you cant take that out its part of the refigeration system
    dont worry about the hose its fine. the noise if it is the pump, and its likley is due to worn bearings. had a few do this and the noise in beyond belief for something so small
    Haramo
    ok about the tube. The worm bearings , are they part of the pump or do I need to order them separately? I didn’t understand the latest sentence.
