Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston Margherita 2000 – I also have a problem!
- This topic has 251 replies, 66 voices, and was last updated 21 years, 9 months ago by
admin.
December 13, 2004 at 9:50 am #112780
KeymasterMargherita 2000 AL128D filter
I have a Margherita 2000 AL128D
I’m wondering where the filter is so that I can clean it.
Can anyone help? I don’t have a manual 😥December 13, 2004 at 10:36 am #112781Dave_Conway
ParticipantRe: Ariston Margherita 2000 – I also have a problem!
It’s behind the kick plate (plinth) at the very bottom Helen.
If you give it a tug it should unclip, the filter is behind it on the right.
December 13, 2004 at 10:47 pm #112782admin
KeymasterRe: Ariston Margherita 2000 – I also have a problem!
I have an error code F-05 showing. What does that mean? Thanks.
December 13, 2004 at 11:01 pm #112783Dave_Conway
It’s a water level related problem.
The only thing the user can really check is the filter for blockages/coins etc.
Apart from that, you’ll need to call an engineer to diagnose which component is causing the error to display.
There’s plenty here if you need one, just let us know your postcode.
December 19, 2004 at 9:37 am #112784admin
Dave_Conway wrote:It’s behind the kick plate (plinth) at the very bottom Helen.
I cannot get the drier to work no matter what settings i use and do not have a users manual. A service engineer said the control panel was faulty and he supposedly repaired it, but still no luck. Does anybody have any clues or similar problems?
December 19, 2004 at 11:32 am #112785Martin
mark-Nottm wrote:A service engineer said the control panel was faulty and he supposedly repaired it, but still no luck.
Mark,
I would suggest calling that engineer back to check it out. The work he did should carry a years guarantee (the norm in the trade). It is likely that it may need further attention in that department I suspect 😉
You can download an instruction book by checking my posting under “Instruction Books” within this forum.
January 7, 2005 at 3:59 pm #112786admin
I have a problem with one of these too. It takes in water at the beginning of the cycle then when the drum is supposed to turn, nowtr happens and the dial does that turny thing. I’ve checked the filter, reset the machine and checked that the belt is still in one peice. Any ideas? Is it worth taking off the pipework to the pump to see if there is any blockages?
Ta!
January 7, 2005 at 4:06 pm #112787clyde
When the dial is clicking round the power light will be flashing. Count the number of flashes it will pause briefly then keep repeating the code. The amount of flashes indicates an error code.
Clyde 😆
January 9, 2005 at 9:29 am #112788admin
Fixed it! I took it apart and found that the pipe that leads down from the detergent tray had become unattached for some reason, so I put it back on and all is well. Strange!
November 27, 2005 at 11:56 am #112789colinb
I have a Margherita 2000 AWD 12 S.
I have been having a similar problem with the program getting stuck.
I removed the screw in filter plug, but unfortunately the filter was so blocked with coins etc, I snapped off the plastic filter in the process.
where would I be able to purchase a new one ?
Thank you
November 27, 2005 at 12:12 pm #112790Penguin45
Looks like a complete pump Colin 🙄
http://www.ukwhitegoods.co.uk/modules.p … cts_id=392
Is the one you want.
Penguin45.November 27, 2005 at 6:32 pm #112791colinb
thanks for the quick reply 😀
I’m not sure that’s the part I want…
it’s the actual cover that unscrews – is it possible to buy a replacement ?
November 27, 2005 at 6:37 pm #112792Martin
colinb wrote:I’m not sure that’s the part I want…
Colin,
That part includes the cover you refer to 😀
November 27, 2005 at 6:40 pm #112793Dave_Conway
Yep, you can buy just the filter, part number C00045027 at £15.21 inc VAt and carriage.
An email to spares@ukwhitegoods.co.uk please if you’d like one 🙂
November 27, 2005 at 8:56 pm #112794Penguin45
Blimey – the whole pump’s under £20 in the shop!
Not logical sometimes……
