Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch 6312 Dishwasher: No Heat
- This topic has 32 replies, 9 voices, and was last updated 21 years, 1 month ago by
admin.
February 17, 2005 at 11:58 am #7996
KeymasterHi.
We’ve had this dishwasher for exactly five years now and its suddenly packed up heating the water or drying. I’ve contacted repairers who dont seem to want to know as they say I might as well buy a new one. Could you please give the chances of this being a faulty heater( which is expensive) as against a circuit board problem and what will be the approximate cost of getting it fixed assuming I an find someone to do it
Thanks.
February 17, 2005 at 1:25 pm #126297Martin
ParticipantRe: Bosch 6312 Dishwasher: No Heat
Pms,
It is likely the circuit board is at fault. In many cases however it can be successfully repaired therefore no spare part required and labour only. So if you were in my service area and such a repair applied, then your looking at £50 tops 🙂
One quick question though first: If you set your machine to ‘reset’ will it indicate “0” (Zero) pump for 60secs then switch off? (See your user booklet if you don’t know how to reset the programmer)
February 17, 2005 at 1:52 pm #126298admin
KeymasterRe: Bosch 6312 Dishwasher: No Heat
Thanks for that Martin. The answer to your question is yes because we did just that when we tried it yesteday and it was obvious that the heater wasn’t working. Is that a bad sign?
Peter
February 17, 2005 at 2:08 pm #126299Martin
Peter,
No, a good sign :tup:
It means the chip within the programme module hasn’t been zapped by this failure and the board can have a ‘soldered link repair job’ done with more than a 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} success rate. It also means the heater is OK too I reckon 🙂
Pop in your details on repairs@ to see if we have a local engineer covering your area 💡
February 17, 2005 at 3:53 pm #126300admin
Thanks again Martin. I tried the repais@ but no-one in our area (OL2)
so will have to try a few more repairers, possibly bosch service centre.Peter
February 17, 2005 at 4:25 pm #126301Martin
pms wrote: possibly bosch service centre.
They will not do the cheap fix I was talking about, so forget them on that! Best try a local company and tell them about our conclusions OK?
February 17, 2005 at 4:35 pm #126302Dave_Conway
You could try these Peter:
Paterson Quality Services Ltd 0161 4773725
They cover the OL postcode area.
February 18, 2005 at 12:30 am #126303admin
Thanks once again . I’ll give them a try. Incidentally , tried a bosch service and they wanted £59 + vat for the first half hour! A complete joke.
Best wishes
Peter
March 2, 2005 at 4:02 pm #126304admin
Further to my posts on this I have had someone round who tested it and said it definitely was NOT the heater that was faulty and he left saying that was as far as he could go and that the circuit board would have to be replaced. Is it likely to be worth going any further with this or am I better off just buying a new dishwasher. Most repairers including this one dont seem to have much of a clue and certainly dont seem to want to test the board to see if it can be repaired.Is there any other particular part that is likely to be the culprit, I had a look on the Bosch spares site and could only see a control module that seemed to be relevant. Any further ifo would be greatly appreciated.
Pete
March 3, 2005 at 1:30 am #126305Penguin45
ParticipantPete,
As we suspected, the heater is fine – the fault is almost certainly a burnt out joint on the computer board at the heater relay. If you know how to use a soldering iron, you can sort this out – check back through the forum and there is an explanation of what is involved.Pull the plug first……..
Penguin45.March 4, 2005 at 3:47 pm #126306admin
Hi again
Thanks for your last reply.
I have checked through all the bosch threads as suggested but cant find anything on repairing the circuit board which I quite happy to have a go at considering there is nothing to lose. One entry from a moderator says its not a DIY repair. Have you any more info or a clue as to where to find it in the postings. I’ve just joined the site as a member so I will be able to receive info by email if that is more convenient.Thanks
Peter
March 4, 2005 at 4:10 pm #126307Martin
pms wrote:One entry from a moderator says its not a DIY repair
That would be me I expect Peter 8)
However if you are the least bit competant at electrical repairs and the use of a soldering iron then it can be done. It requires the removal and close inspection of the Module Circuit Board, the problem will be all too apparent to anyone as the burnt terminals and PCB track are clearly visable.
Before you undertake such a mission you will need first to test if your machines programme will ‘reset’ successfully or not 😕 (see your instruction book on how to reset a programme). Now if it does NOT reset then that tells you that the Module Circuit Board is beyond redemption and will need replacing, so don’t even bother trying at that point. 😥
:zap: DO MAKE SURE YOU UNPLUG THE MACHINE FIRST :plug:
March 4, 2005 at 8:42 pm #126308pms
Thanks a lot Martin
Do I get at the Module Circuit board through the back of the door or is it somewhere else ie under the washer?
PeterMarch 4, 2005 at 8:52 pm #126309Penguin45
ParticipantIt’s in the control panel, directly behind the buttons. Be very careful of the edge of the inner door when you split it, you can shave with it!
:plug:
Penguin45.March 6, 2005 at 1:07 am #126310admin
pms wrote:Thanks once again . I’ll give them a try. Incidentally , tried a bosch service and they wanted £59 + vat for the first half hour! A complete joke.
Best wishes
Peter
It’s £59.50 INC VAT. We do not resolder this heater relay back up as it’s seen as a temporary repair :duck:
