Bosch 6312 Dishwasher: No Heat
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch 6312 Dishwasher: No Heat
Viewing 3 posts - 31 through 33 (of 33 total)
  • #126326
    Re: Bosch 6312 Dishwasher: No Heat
    BSH-MAN wrote:“I’ve lost all respect for Siemens based on that design…..”
    You’re a hard man to please if one fault, on one component, on one appliance can lead you to loose respect for a huge company. 🙂
    Why not loose just a little respect and then save some for later?
    :martin:
    If it were only my board I’d agree with you – unfortunately these forums and online review sites are rife with this fault.
    But you are right, they are large company, and I should pace myself on losing respect for them. :clown:
    #126327
    gegsy
    I wouldn’t despair either, they make some cracking appliances, and I dare say they don’t manufacture the PCB (BSHman??)
    Once that repair is done to the PCB you should have many years of carefree operation.
    I blame the CAD operator 😆
    I’d just like to thank everybody for their advice.
    I had the same problem with my Bosch 5312, no heat, and decided to remove the control panel for a check.
    The control panel did indeed have the burned-out solder joint on the relay.
    I took the panel into work today and did a top solder job on the joint (I’m an Electronics Engineer).
    Fitted the panel back into the machine tonight and ‘Bob’s your Uncle’ I have a working Dishwasher!
    Thanks again for saving me a couple of hundred quid.
    Total cost of repair=£0……perfect!
