Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › candy alise 105 changing bearings
- This topic has 112 replies, 14 voices, and was last updated 20 years, 11 months ago by
yurtesen.
August 19, 2005 at 8:16 pm #132189
KeymasterOkay, I give in.
How can a timer work at 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}? It’s an electro-mechanical device, it works or it doesn’t.
Does anyone know if those were the Candy timers that spontaneously burst into flames? Or not, depending on whether you believe the Candy propoganda machine as then they would only have “failed”. 😉
August 19, 2005 at 8:53 pm #132190Penguin45
ParticipantRe: candy alise 105 changing bearings
92745272 is the part number for this programme timer, and it is over £100, plus VAT, plus P+P.
Contact spares@ukwhitegoods.co.uk for exact prices and ordering.
Penguin45.August 20, 2005 at 8:35 pm #132191yurtesen
Participantkwatt wrote:How can a timer work at 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}? It’s an electro-mechanical device, it works or it doesn’t.
K.Well, right the timer is a mechanical device which opens and closes switches all the time. However in time when it wears off the switches sometimes do not close properly, it depends on where the program is since at a place where many switches should be closed the pressure is higher and the whole system bends a little bit from the pressure etc.
It is not easy to explain really but it works 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} due to the fact that the machine doesnt get flooded and it washes clothes good 🙂 However I feel that it doesnt turn the drum everytime it is suppose to. This is especially a little problem in rinse since I realized that it sometimes do not cycle at one or two of the three rinse cycles.
Evren
August 20, 2005 at 8:41 pm #132192yurtesen
92745272 is the part number for this programme timer, and it is over £100, plus VAT, plus P+P.quote]
Is it possible to be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure about this part number? I found the number from:
http://www.rei-components.com/commerce/ … odotto=147
According to the picture from the side of the timer:
http://master.titol.fi/~yurtesen/CIMG0706.JPG
It says Type 2000/2008-3163
So the part number should be right, isnt it? (Although the picture in the site is different, it seems like a generic picture so…)Evren
August 20, 2005 at 8:48 pm #132193kwatt
KeymasterIIRC those timers have been modified Evren, hence my comment about fires and, if they have then the number won’t tie on the actual spare itself.
August 21, 2005 at 11:26 am #132194yurtesen
ParticipantIIRC those timers have been modified Evren, hence my comment about fires and, if they have then the number won’t tie on the actual spare itself.
That doesnt make any sense. How can one know which part he/she is ordering if all the part numbers are modified and now they have different meanings?
But cant one see from the database the type number 2000/2008-3163
while ordering the part?So what you are saying is that if I order the timer with that part number, it wont be the same or compatible with the one I have now?
Thanks,
EvrenAugust 21, 2005 at 12:59 pm #132195kwatt
KeymasterAugust 21, 2005 at 1:06 pm #132196kwatt
KeymasterEvren, maybe I should explain…
We often get this, modified spares that is, and when it happens we have to usually follow the trail to get a price on it. The information in that article is valid in that all we see is a line drawing, we get very little additional information more often than not. This means we get no timer numbers as they’re only really for production purposes as a general rule, no measurements and no photographs, in fact, we often don’t know whether the part is right or wrong till we have it physically in our hands.
And, should the spare be modified, it’s not entirely unusual for us not to be told, sometimes we are simply expected to guess or work it out.
Good innit? 😉
August 22, 2005 at 5:46 am #132197yurtesen
Participantkwatt wrote:we often don’t know whether the part is right or wrong till we have it physically in our hands. And, should the spare be modified, it’s not entirely unusual for us not to be told, sometimes we are simply expected to guess or work it out.
Good innit? 😉
K.Yes, but if the part is wrong when you physically get it, you wouldnt send it to your customer right? or if that happens that the part is different but uk whitegoods didnt realize it. Then you would accept a return of an unused part, right? I have made very detailed pictures of the timer itself. Anyhow, I think I have to take the risk… 🙂 Thanks for the warning though…
Evren
August 22, 2005 at 7:21 am #132198Martin
Participantyurtesen wrote:This is especially a little problem in rinse since I realized that it sometimes do not cycle at one or two of the three rinse cycles.
💡 Sticking dispenser linkage perhaps?
August 22, 2005 at 11:14 am #132199yurtesen
ParticipantMartin wrote: 💡 Sticking dispenser linkage perhaps?
Well, I know it is the timer. It kind of has been my guinea pig. I had to open it several times to pieces and put back, because it took 5-6 tries to find out exactly what sticks best inside the timer. However I think it wasnt designed for opening/closing that many times. So it doesnt turn right position sometimes and goes few mm extra, but when I move it by hand a bit backwards then things start working normally again 🙂
Evren
August 22, 2005 at 12:59 pm #132200Martin
Participantyurtesen wrote:Well, I know it is the timer………….. but when I move it by hand a bit backwards then things start working normally again
Yes indeed from what you say, the Timer is in fact, as we say in the trade here in the UK…..
……NUKED
September 16, 2006 at 5:40 pm #132201yurtesen
ParticipantHi all, just came to check up how things are going here 🙂
With the new timer and bearings, the machine has been working for a year now. I would like to thank all of you for your comments, tips and advices.
The machine is used almost daily and some days 3 times a day. (lots of dirty clothes :p) I think I can consider this as a success.
Thanks again,
EvrenJanuary 5, 2007 at 12:07 pm #132202zaff
yurtesen,
Hi, wonder if you spare me 5 mins of your time. You’re obviously very experienced with Candy washers. I have a 13 yr old Candy Aquaviva 1000 machine. The bearings have just gone. I have stripped the machine as much as I can, got the motor off. Just the drum housing left in the machine. Do I need to remove the drum outer housing out of the chassis? Is it a sealed type drum like in your alise 105? Or once I undo the pulley bolt at the back at will magically open up (silly questionI know). Never done one of these before! if the drum needs to come out, is it best to lie it on one side and slide out the drum housing, or do I have to get help and lift it out the top?
I would really appreciate a response soon. It has been out of aciton for a week now. Wife pushing me to buy a new one (can’t afford it), and a young family’s clothes piling up.
Appreciate any advice.
ZaffJanuary 5, 2007 at 12:21 pm #132203kwatt
KeymasterYes it is sealed in the same way and yes it is the same nightmare of a job.
Teh whole tank needs to come out the top to do it.
