Re: Electrolux fan Oven EOB5630 keeps cutting out
Yep, quite true. I just thought someone may know for sure that if there’s no heat it is most likely to be the element and in no way connected to that fan cut out sensor thingymajig 🙂
As it happens the new element arrived yesterday but was too small, the supplier listed my oven model with it by mistake (It needed to be 50mm larger) and I’ve since took the old one off and tested it with a multimeter and can confirm it has no continuity. I didn’t know they could be tested like that until you said so thanks, a good tip for the future.
