Fisher & Paykel error codes
Viewing 15 posts - 16 through 30 (of 53 total)
  • #144965
    wjbrambley
    Re: Fisher & Paykel error codes
    wbrambley wrote:Hi, what does the short wash, second rinse light and the spin light mean in diag mode? Machine has been stopping during a cycle almost as if its software had hung Now it will only fill for a second and stop. Starts filling for another second and stop. then from what i can tell it goes into diagnostic mode by itself.machine is a gw503k. Any help would be great as it is only a matter of time before i pull it down bit by bit. 🙂
    Sorry about that, from right to left they are: on,on,off,on,off,off,off,off. thanks.
    #144966
    11 – pressure sensor error. This is the water level control switch and it’s integral with the main pcb.
    Try:
    Pulling off the air hose and ensuring that it’s not blocked, nipped, trapped or holed in any way. If that doesn’t do it, the pcb is the culprit.
    daw_z
    Glad I found this forum…
    I have a SmartDrive9 Pride 5.5 with the following error code:
    Off, Off, ON, ON, ON, ON, ON, Off.
    Any help would be greatly appreciated. (Guessing new pump needed, but i wouldnt have a clue!!)
    #144968
    bigsmokepiker
    Fault code 62 (Pump Fault over current) can also come back to Motor Controller
    #144969
    Nasty
    Hi there,
    Great Forum by the way.
    I have a SmartDrive 9 5.5 as well.
    MW059AU
    Error codes are
    off off on off on off on on
    Thanks again.
    #144970
    bigsmokepiker
    Fault Code 43 OOB Switch Fault
    Numerous Threads For The Fault Code
    #144971
    Nasty
    ok replaced the switch and all good. But…..
    Next error I get is
    off off on on off off on off
    Thanks guys.
    #144972
    bigsmokepiker
    FAULT CODE 50
    Hot water valve fault
    Check connections to hot water valve
    Could be faulty Valve itself
    Have you got the tap turned on? to hot water
    #144973
    versatech7
    Hello all, new to this forum thing but here goes.
    Inherited a GW712 with the house and it goes straight to 0 1 0 0 0 0 1 0 on power up with constant beeping.
    I’m able to get it into DMode by holding the “wash temp down”+”Power” button then switching on mains, two beeps then toggle spin buttons to get “slow” and “spin” lamps lit. Same code as above.
    I believe from what I’ve read this is a “66” code relating to the pressure switch and needs to have the motor control module replaced?
    Was able to get the bowl pumped out by applying pressure via tube to sensor (it actually did a small cycle so I set it to a full load).
    Am I up for a new controller or is there any thing else I can do.?
    This is a legendary site. Thanks.
    #144974
    versatech7
    Further to the above, thinking that I was on my way to a less than $100 fix on my 708 (have one of these that I thought had shot bearings), I’ve just pulled that apart (708) and the hub of the stator is actually breaking up, causing the stator to go off centre and contacting the magnets in the rotor.
    This machine is 13 years old and has had a flogging, it wasn’t going to last forever. The rest of the machine is in very good condition, although some of the plastic has had a lot of stress from a couple of OOB issues over the years. I’d buy another one in a heartbeat.
    Don’t think it would be worth fixing though as a new stator would be worth $$$$$ I expect.
    Oh well, nothing lasts forever.
    Simmo.
    #144975
    minds
    Hi there I have a Fisher and Paykel Pride with the following from right to left
    off on off off off off off on
    if left to right at the console it would be the first light (long wash) and the second to last light between rinse and spin
    stops and starts goes one minute surges the next then bleeps
    any info is good
    minds
    #144976
    Desailly
    Thanks for such a helpful forum.
    I have a F&P smartdrive GW709AU with the following error sequence (right to left):
    on, on, off, on, off, on, off, off
    Would appreciate advice on what the error code is and if it might be something I could fix myself or if I’ll need to get a technician in.
    Thanks.
    #144977
    Desailly
    Hi – after reading through the posts in a bit more detail I think I’ve figured out the error is 43 – balance switch. I would like to attempt to replace it myself if it’s not too difficult. I’ve done an internet search for the part and it seems you can buy generic ones much cheaper than the F&P ones. Are the generic ones OK to use? Anyone had any problems with them?
    #144978
    bigsmokepiker
    Can use these Micro switches no drama
    #144979
    elks4
    I have a problem with my fisher & paykel washer model GWL03. it powers up but will not start. I went into diagnostic mode:
    lights for slow/hold spin mode are from left to right: on off off off off off on on
    If I am reading them correctly the error code is 193 or 131 depending on how it is read?
    Can anyone help me.
    If I have entered the wrong forum or am violating any protocol please forgive me as I am new to this kind of thing.
