Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Fisher & Paykel error codes
- This topic has 52 replies, 27 voices, and was last updated 20 years, 7 months ago by
admin.
August 11, 2010 at 7:42 am #144980
kesubi
ParticipantTo elks4. 1st check wiring and edge connector of rotor position sensor for corrosion. 2nd. Check RPS. Replace if faulty. 3rd. Replace motor control.
August 14, 2010 at 1:58 am #144981Byro
ParticipantRe: Fisher & Paykel error codes
Hi I’ve got a Smart drive 700. (which i’m assuming is a gw700)
The problem is when the machine is on I can hear a pump going even before a cycle starts. It won’t do the spin cycle, it just beeps once per second when it gets to it and shows the short wash light.
I’ve done the diagnostic and I got
Off Off Off Off ON ON Off ON
August 14, 2010 at 5:22 am #144982kesubi
The module has detected the pump is on when it should be off.
Unplug the machine to do any checks.
1.Check if the thermal cutout has activated and if so wait till the pump cools down before restarting.
2. check for blockage and condition of pump before restarting.
3. check for open circuit pump windings and the resistance should be 26ohms @ 20 degrees C for a compreci pump or 33ohms @ 20 degrees C for a Selni brand pump.Check pump wiring for open circuit as well
Ive had this fault too and a new pump fixed it.
Last fix in the list is replace the display module.
August 28, 2010 at 3:01 am #144983brackent
hi l,ve got a f&p smart drive “9” 6.5.stopped working last week.it humms very quietly with a beep every sec and three lights on .reading this forum it seems to have a diagnostic fault code of 104.any advice would be welcomed thanks
August 30, 2010 at 5:13 am #144984kesubi
To Brackent. Remove the plug from the wall and tilt back. Remove the pump. Check the resistance of the pump. If its less than 33ohms replace it. Please reply with result.
September 1, 2010 at 12:13 pm #144985WazzaAndWenches
Problem with a GW701-u washer.
Works till random place in the wash cycle then stops with continuous beeping. Lights up as follows… off off off on off off off off.
Need to power off then on and Advance to restart. Regularly faults again during the remaining cycle. Eventually need to advance to Final Spin to complete the wash.Have pulled out the pump and checked it’s clean.
Tried Diag mode. Don’t get the two beeps but still appears to be in Diag.
Fault sequence is on off off off off off on off. Also has Spin Slow/Hold and Water Level High/Low lit up.Help very much appreciated as local service agent has proven to be far less than competent on other appliance and next closest agent is 90km away 🙁
September 3, 2010 at 7:04 am #144986kesubi
Wazzawenches. With power off
1. Check for corrosion on the edge connector of the Rotor Position Sensor and the Motor Control Module connector.2. Check the contacts on the rotor positional sensor end of the hall harness to see if any have been damaged. (Each set of contacts in
the socket has two wipers. If the distance between these wipers varies between different contacts, replace the rotor positional sensor harness.)3. Check rotor position sensor for corrosion or black burn marks. Replace if it has these. If it has burn marks check the motor windings for a similar black mark and if present replace the windings too.
4. If everything above checks ok replace the motor controle module.
October 18, 2010 at 9:53 am #144987gasgrassorarse
Penguin45 wrote:Numerically, right to left, which lamps are lit? This is all in the diagnostics thread at the top of the forum if anyone ever bothered to read it.
I read the sticky, but mine shows no lights at all on that diag test.
(hold and slow lights are on)
Is it possible for someone to put a screenshot of the machine, and explain how to read the codes as I thought it was read left to right but now read it is right to left in binary, and I cant workout how to “add” the numbers together.
November 10, 2010 at 10:01 am #144988Justo2
I have a F&P gw709au with a fault code:
off, off, on,off,on,off,off,off
The machine often stop mid cycle and occasionally fills and overflows. If you can help with the diagnostic code it would be great.
Regards
JustoNovember 14, 2010 at 8:14 pm #144989toxaq
@justo2 00101000 according to a manual I found online is “Phase 1 to 6 – Bowl Dis-engage Fault.” “check are the clutch and the pressure tube.” I have no expertise in this area however.January 10, 2011 at 5:19 am #144990cadfiend
ParticipantHi,
Looking for the error code for 11110100.
Any help would be appreciated. GW708UJanuary 10, 2011 at 10:20 am #144991PaulK123
ParticipantI have a GW712. When it gets to the end of the wash cycle pump starts, but it does not empty completely and will not go on to the refill and rinse cycle. I can coax it along turning it on and off a few times and eventually it will get going but will stop again at end of rinse before it spins. Again the machine will not empty properly and wont spin. With a lot of mucking about I have managed to finally get it going to complete the spin, but next wash its the same story over again. When it stops lights 1 3 6 are lit (right to left) 1 + 4 + 32 = 37
Help would be much appreciated ThanksJanuary 10, 2011 at 9:43 pm #144992PaulK123
I found error codes here; http://www.docstoc.com/docs/25379715/?u … ign=newreg
37 Pump blocked error. The pump seems to be fine until about 70{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the water has been pumped out (beautifully with good pressure). Must be another sensor. Could the pump be overheating? Any help would be appreciated.
October 27, 2011 at 9:36 pm #144993KwinT
Hi i have a Fisher & Paykel smart drive 9 and the LED lights up 3578 help please. 🙁
October 30, 2011 at 6:37 pm #144994KwinT
code is, off off on off on off on on
