Forum Format Change
Home Forums UK Whitegoods Moderator/Site Admin Forum Forum Format Change
Viewing 15 posts - 1 through 15 (of 52 total)
  • #7427
    I’ve been thinking, which is dangerous at best….
    The public forums what’s the thoughts on changing it to….
    Format as is but adding….
    Public Refrigeration
    Public Laundry
    Public Dishwashing
    Public Cooking
    Public Other Appliances
    So we can delegate and monitor better, dunno, what do you guys think?
    Public Diplomats……… :rotl:
    It’s going to make the forum front page very long unless we split the existing forums into the new ones. That’ll be a job for someone…… 😯
    Overall, it would make a lot more sense – the public do seem to post anywhere almost at random.
    That was the idea P, to get it more specific which should I would hope help people find things more easily and save answering the same questions over and over.
    Re: Forum Format Change
    Best “Rule of Thumb” to adopt by far is KIS(Keep It Simple)
    Nothing wrong with: Public Help, Public Parts etc etc. Splitting them further into sub-categories will only add to the confusion.
    kwatt wrote:Public Laundry
    They’ll be sending in their dirty washing if we’re not careful under that heading :rotfl:
    Dave_Conway
    Noooooo !! Not adding, changing yes, a good idea, if there’s even more there it will be get worse and more diverse IMO.
    If we were to change them who’s going to move all the existing one’s ? As P says, one hell of a task involved 😯
    Agenda topic for Saturday 26th that one maybe ?
    #123166
    Well, actually…
    Plan B was to remove Public Help, Site Support and Tips & Tricks as they are little used and there’s not too much to move bar the help one. So in effect we add one forum but get it a lot more specific and easier for the punters to navigate.
    To be honest I’d give up on the site support one as well as that’s also little used.
    Dave_Conway
    Yep, go for Plan B 😀
    #123168
    plan b then……is that todays plan b or yesterdays :rotfl:
    #123169
    Okay, started.
    Let’s do them one at a time and clear them as we can.
    Go to “moderate this forum” then tick the ones you want to move, select the “move” button and you’ll get a drop down of where they can be moved to. Untick the “Leave Shadow” box as that would leave crap we don’t want.
    I’ll do more as I see them but this should make things a lor clearer for the punters.
    With apologies for my earlier post on the idea, Plan B does look good, really very neat and easy for the punters to understand and hopefully post correctly. 😀
    Whats happened to your Avatar Kevin…is that “Plan C?”
    Dave_Conway
    It’s essentially done now, all that remains is to trawl the general public forum and move the duplicates and any posts to their new home 😀
    #123172
    …and what a job that is, I’ve moved shedsloads so far its taken me over an hour and I have only cleared Decembers posts!!!!!!!!!
    Dave_Conway
    You can move multiple posts all at once Martin.
    Go the very bottom and select “moderate this forum” this link:
    http://www.ukwhitegoods.co.uk/modules.p … =modcp&f=5
    you can then check as many of the posts you want to move all at the same time to the same forum.
    On that note, there’s no moderators installed on the new fourms I just noticed 😯
    #123174
    Oh yee of little faith! 😆
    Get the mods sorted out later when I have time.
    Dave_Conway wrote:You can move multiple posts all at once Martin.
    Now he bloody tells me :haier:
    But neverless thanks for that Dave, and on that advice I have done shedloads more in a fraction of the time. I can sort the rest if you guys like. ❓
    CAUTION to other volunteers though………….???? DO BE CAREFUL WHICH BUTTONS YOU PRESS….RULE OF THUMB>>>DOUBLE CHECK WHAT YOU WANT TO MOVE OR DELETE AS YOU CAN SCREW LOADS UP WITH THIS<<<<<<
