Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hoover ppw166 washer/dryer
- This topic has 31 replies, 4 voices, and was last updated 14 years, 2 months ago by
john_d.
January 31, 2012 at 2:06 pm #67666
john_d
Participanthoover pww166 washer/dryer
both the start and pre wash lights flash 5 times, pauses, then repeats the flashing sequence, wife is already looking at new one, please tell me there is a cheap quick fix! :eeek:
January 31, 2012 at 4:50 pm #368118kwatt
KeymasterRe: hoover ppw166 washer/dryer
Can you check the model number as that doesn’t appear anywhere?
January 31, 2012 at 5:11 pm #368119john_d
ParticipantRe: hoover ppw166 washer/dryer
hi its a PPW166 not pww as i previously mentioned.
January 31, 2012 at 5:16 pm #368120john_d
for confirmation PPW166
January 31, 2012 at 5:21 pm #368121iadom
ModeratorRe: hoover ppw166 washer/dryer
5 flashes = Faulty NTC Temperature Reading Probe and/or Wiring
and/or “Core” Board.January 31, 2012 at 5:24 pm #368122john_d
are these parts available from anywhere?
January 31, 2012 at 5:33 pm #368123kwatt
That didn’t come up on GIAS.
Yes the parts will be available but you will need to know what you need.
January 31, 2012 at 5:36 pm #368124iadom
kwatt wrote:That didn’t come up on GIAS.
😕 Worked for me.??
January 31, 2012 at 7:23 pm #368125john_d
iadom wrote:5 flashes = Faulty NTC Temperature Reading Probe and/or Wiring
and/or “Core” Board.is there a way to find out which is faulty?
January 31, 2012 at 7:32 pm #368126iadom
Wiring connections are the first thing to check, look for loose or broken connections to NTC.
Resistance of NTC at room temp should be checked and if possible a ‘hot water’ test on the NTC with it removed from the machine using a cup of hot or near boiling water to see if the values alter with change in temperature.
January 31, 2012 at 7:34 pm #368127kwatt
That’s for fridges but the same general principles apply.
You also need to check the connectors and wiring are good then, once all that’s eliminated start thinking about the board.
If you don’t check it and order a board you could end up with an expensive controller and the same problem.
HTH
January 31, 2012 at 7:37 pm #368128iadom
Reading should be approx 19500? @ 25°C.
January 31, 2012 at 7:45 pm #368129john_d
sorry to be a pain but is this what im looking for?
January 31, 2012 at 8:04 pm #368130john_d
if it is the above pic
room temp around 20k, in hot water around 9k
January 31, 2012 at 10:11 pm #368131iadom
That seems about right, can still be faulty or be due to bad connections between NTC and PCB.
The bottom line is that a new NTC is a few pounds, a PCB is serious money.
