hoover ppw166 washer/dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hoover ppw166 washer/dryer
Viewing 15 posts - 16 through 30 (of 32 total)
  • #368132
    john_d
    Re: hoover ppw166 washer/dryer
    i’ll see if i can source 1, tbh i can see this ending with the wife just buying a new machine!
    #368133
    john_d
    ive ordered a new NTC so hopefully it will be here before the weekend.
    #368134
    john_d
    a little update.
    if i hold the start button whilst turning the dial to select a program type it will partially fill with water then stop, i did this 3 or 4 times and manage to get it full, i then did it again when full and the drum spinned, not just a normal spin but as if it was doing a rinse (full speed), does this point to anything?
    #368135
    john_d wrote:does this point to anything?
    Yes, user abuse. Do please select the programme you want before pressing the start button otherwise you’ll screw up the programmes software most likely. 😯
    #368136
    john_d
    if I do that nothing happens bar the flashing lights.
    #368137
    The Start LED and the one next to it flash in sequence that represents an error code. The 3 remaining should not flash however and if they do I can only think that the Coreboard (Main PCB) has failed. 🙁
    #368138
    john_d
    Martin wrote:The Start LED and the one next to it flash in sequence that represents an error code. The 3 remaining should not flash however and if they do I can only think that the Coreboard (Main PCB) has failed. 🙁
    its just the start and the pre wash that flash, 5 times.
    #368139
    john_d wrote:its just the start and the pre wash that flash, 5 times.
    Fair enough, so you’re back to square one on this meaning there’s a strong possibility the fault lies with the PCB or the connections from the NTC to the PCB.
    Also it’s worth pointing out that it is important to use a 500volt insulation tester to ensure no spurious earth leakage is causing the PCB to give erroneous messages. We in the trade use them as a matter of course but chances are you do not have such a facility to hand. If you have, then well for you as it may be invaluable. A multimeter is useless for such detective work but at least you can still test those PCB connections with one! 🙂
    All the best!
    #368140
    john_d
    [quote=”Martin”Also it’s worth pointing out that it is important to use a 500volt insulation tester to ensure no spurious earth leakage is causing the PCB to give erroneous messages. We in the trade use them as a matter of course but chances are you do not have such a facility to hand. If you have, then well for you as it may be invaluable. A multimeter is useless for such detective work but at least you can still test those PCB connections with one! 🙂
    All the best!
    now you mention earth leakage, i should have mentioned this (memory’s not the greatest 😥 ), for about a month maybe 2 the fuse/relay in our electricity mains thingy has tripped when the washers been on, it hasn’t done it often 2-3 times maybe in 2 months, we’re not sure if its the washer but it has always been on when its happened, but so has the fridge etc.
    #368141
    Well I never…..my suspicions are well founded it seems. 😉
    #368142
    john_d
    Martin wrote:Well I never…..my suspicions are well founded it seems. 😉
    cool, so i need to………………………………….
    #368143
    john_d wrote:cool, so i need to………………………………….
    Test the insulation of the components especially the heater and motor. 😉
    #368144
    john_d
    dont i need a leak tester?
    #368145
    john_d wrote:dont i need a leak tester?
    Didn’t I suggest that to you only 2 posts back? 😐
    #368146
    john_d
