hoover ppw166 washer/dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hoover ppw166 washer/dryer
Viewing 15 posts - 1 through 15 (of 32 total)
  • #67666
    john_d
    hoover pww166 washer/dryer
    both the start and pre wash lights flash 5 times, pauses, then repeats the flashing sequence, wife is already looking at new one, please tell me there is a cheap quick fix! :eeek:
    #368118
    Re: hoover ppw166 washer/dryer
    Can you check the model number as that doesn’t appear anywhere?
    john_d
    hi its a PPW166 not pww as i previously mentioned.
    #368120
    john_d
    for confirmation PPW166
    #368121
    5 flashes = Faulty NTC Temperature Reading Probe and/or Wiring
    and/or “Core” Board.
    #368122
    john_d
    are these parts available from anywhere?
    #368123
    That didn’t come up on GIAS.
    Yes the parts will be available but you will need to know what you need.
    kwatt wrote:That didn’t come up on GIAS.
    😕 Worked for me.??
    #368125
    john_d
    iadom wrote:5 flashes = Faulty NTC Temperature Reading Probe and/or Wiring
    is there a way to find out which is faulty?
    #368126
    Wiring connections are the first thing to check, look for loose or broken connections to NTC.
    Resistance of NTC at room temp should be checked and if possible a ‘hot water’ test on the NTC with it removed from the machine using a cup of hot or near boiling water to see if the values alter with change in temperature.
    #368127
    Some stuff about thermistors.
    That’s for fridges but the same general principles apply.
    You also need to check the connectors and wiring are good then, once all that’s eliminated start thinking about the board.
    If you don’t check it and order a board you could end up with an expensive controller and the same problem.
    HTH
    Reading should be approx 19500? @ 25°C.
    #368129
    john_d
    sorry to be a pain but is this what im looking for?
    #368130
    john_d
    if it is the above pic
    room temp around 20k, in hot water around 9k
    #368131
    That seems about right, can still be faulty or be due to bad connections between NTC and PCB.
    The bottom line is that a new NTC is a few pounds, a PCB is serious money.
