Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › HOTPOINT VTD20G T/D
- This topic has 32 replies, 10 voices, and was last updated 19 years, 1 month ago by
mbdas.
February 27, 2007 at 2:43 pm #25419
mbdas
ParticipantHi 🙂
A friend has this machine and its just 14 months old and the rear drum shaft has worn to a point were its snapped and the belt has also broken.
Ive replaced a few belts on some of these T/D before and they are extremely tight to fit so its no wonder its broke the shaft 😕 does anyone know the part numbers for the belt and shaft also is there any modifications to do to drums on these ❓
Thanks Mark 🙂February 27, 2007 at 8:12 pm #205768iadom
ModeratorRe: HOTPOINT VTD20G T/D
Shaft is 1703080
Belt is 1703666. New belt is a nine rib belt.Jim.
February 27, 2007 at 8:29 pm #205769mbdas
ParticipantRe: HOTPOINT VTD20G T/D
thanks Jim 😀
February 28, 2007 at 8:49 pm #205770gazza57
hi the replacement drum has a modified profile and gives approx 10mm more clearance at rear to cabinet this cures all the scrapping probs with the drums there is also modified drum for the condenser driers. regards gazza
February 28, 2007 at 8:54 pm #205771helo_75
ah ye, the vtd drum is 1703662.. the condenser drum is 1703663
solves all the trouble
February 28, 2007 at 10:13 pm #205772iadom
THe drum kit for the VTD is quite a sensible price at around £34.00 + vat list price, however the kit for the CTD is almost £76.00 + vat 😯
March 1, 2007 at 7:22 pm #205773helo_75
the difference?
not a lot to be honest
only the ctd drum come with a template and instructions on how to change the paddles over
March 1, 2007 at 7:37 pm #205774iadom
helo_75 wrote:the difference?
Oh well, that explains a lot, exceptional value don’t you agree. :rolls: 😥 🙂
March 1, 2007 at 7:42 pm #205775mbdas
Hi 🙂
If I get 1703662 what comes with it do you know ❓ Is it just the drum or is it part of a kit ❓ Ive orderd a shaft and belt but can see this happening again due to it being unbelivabley tight :rolls:Thanks Mark 🙂
March 1, 2007 at 7:44 pm #205776iadom
The mod is mainly to stop the drum touching the back panel, the belt is still as tight, what on earth was wrong with jockey pulleys, they have done the job perfectly for more than 40 years. 😥
March 1, 2007 at 7:47 pm #205777Penguin45
iadom wrote:what on earth was wrong with jockey pulleys
Using the stretch belt gets rid of a least 7 other components……. Money, it’s all down to money.
March 1, 2007 at 9:16 pm #205778helo_75
the drum comes as just that.. a drum (different profile) and a shaft
usually, u’d need the front supports(part of shaft kit), cos they were modified too, oh, and a belt, that was modified as well
QUALITY
March 1, 2007 at 9:43 pm #205779indespoint
I know on the vented dryer they changed to a 9 rib belt as opposed to the 6 rib one.
Question 1 ; If the belt is now 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} wider does it mean it will last longer before it snaps again?
Ok I know i work for the company but to me the belt should have been lengthened. The belt has to be stretched 55mm so it will fit on the motor shaft. The rear bearings wear and snap drum shafts and wear front bearings away due to the tension in belt. Not rocket science is it. Actually its one of newtons laws.March 1, 2007 at 9:56 pm #205780helo_75
nope.. the belts arent any better
like u ive fitted loads
ive took to fitting the 1701658 belt on them, and it seems to last longer
NOTHING will stop these dryers breaking down
March 1, 2007 at 10:03 pm #205781indespoint
Like i said helo its not rocket science if a belt snaps because it has to be stretched 55mm something has to give. The belt you fitted in place of 1703666 is a better belt. I know a few engineers who fit them. If the belt was only streched 25 mm it would not cause the problems and there would still be enough tension to drive drum quite merrily.
Question; How do you get the powers to be to reliase this fact? -
