**KNOWN ERROR CODES**
Viewing 15 posts - 136 through 150 (of 151 total)
  • #103983
    Allsorts
    Re: **KNOWN ERROR CODES**
    On all of these errors/faults, check the capacitor C17 for domeing, remove & replace as necessary with 10v 680mf.
    Indesit WIL, WIDL, IWM, IWME, possibly others too
    Horizontal row of lights flashing
    F09 Flash, OFF, OFF, Flash, eprom/setup error
    Hotpoint WF, WD, BWD and WT
    Vertical row of lights flashing
    F09 Flash, OFF, OFF, Flash, OFF, eprom/setup error
    Hotpoint WF, WD, BWD and WT & Indesit WIL, WIDL, IWM, IWME,
    No power or lights lit
    #103984
    Currys Logik Series Washing Machines
    E10 Fill time-out
    E12 Overflow protection tripped
    E21 Drain time-out
    E30 Door Interlock
    E60 Motor problems
    E61 Motor speed problems (tacho)
    #103985
    Bosch, Neff & Siemens Ovens
    Er1 = Temperature Sensor failure
    Er2 = Faulty mains connection
    Er4 = Temperature sensor failure
    Er6 = Door lock defective
    Er7 = Release mechanism of door lock defective
    #103986
    Beko Washing Machine access to diagnostics
    How to access diagnostics for most models of Beko
    #103987
    adv
    BEKOBOY wrote:I will post all the beko test programmes for all appliances soon, will be a large file so might sent it to ken to post it…..
    where are they beko man ? 😥
    #103988
    adv wrote:where are they beko man ? 😥
    Maybe on Ken’s 50 quid a year app?
    #103989
    adv
    is that the script is it :rolls: ?
    #103990
    Actually Martin, almost all the error codes on the app are available for free if you bother your backside to use Google, you know, that search engine thingybob on the interweb. Or, here’s an idea, you could search this very site where you’re almost sure to find most if not all on the app.
    But, if you want it all convenient and packaged up with some extra info *I* write on your phone as you work without having a connection to the internet that *I* pay for the development of and maintenance of then yeah, that has a cost. Just like you get paid to go fix stuff, I want paid to do some stuff as well, I do enough for free as it is.
    If you don’t like that, tough titty.
    If you think I’m doing that work and sustaining that cost for nothing, you’re dreaming.
    And, quit it with the snide comments. If you want to have a pop at me at least man up and do it head on rather than sniping from the side like an old fish wife.
    You can get all the info for free on here or, as stated, use Google and do your own research.
    Or, pay for it.
    Your call.
    FYI, bekoman never published them and, to my knowledge, he no longer works for Beko. He left not long after the posts he made.
    Perhaps you should have asked and/or got your facts straight before shooting off your mouth as usual Martin and p1ss1ng me off in glorious style with your snide attitude.
    In answer to your question adv, “is that the script is it”, no, it isn’t. It’s just the way some plonker/troll would like to portray it.
    There you go Martin, you got your reaction. Ball in your court, wanna play?
    Andy jones
    This is the most useful thread on the site. Yea sometimes takes a while to find what you want but not a problem. Can’t we keep the squabbling and chest thumping to another threard
    #103992
    Andy jones
    “Thread”
    #103993
    Jackal
    Not to mention being one of the funniest when Martin joins in!
    #103994
    Bernie
    Indesit DW – EOS Alarm Table (DEA 601/DEA 602/DEA 700)
    #103995
    murv
    Fault codes for Whirlpool/Hotpoint/Indesit Tumble Dryers fitted with an Arcadia module
    F01 – Motor Circuit Fault
    Check motor & wiring
    Check heater circuit or Compressor & wiring on heat pump models
    F02 – Motor Fault O/C or Short circuit
    F03 – Front NTC
    Check NTC & wiring (Aprx range 100K at 25C to 2.3K at 140C)
    F04 – Rear NTC – No rise in temperature detected
    Check Heater circuit
    Check NTC (Aprx range 50K at 25C to 6K at 80C)
    F06 – Heat Pump Refrigerant NTC Open or Short circuit
    F07 – Compressor Open or Short circuit
    Check the compressor, capacitor and wiring
    F08 – Heater Open or short circuit
    F09 – File Setting Corrupted
    Reprogram module
    Replace module
    F12 – Communication Error
    F13 – Air Duct NTC Overheating
    Check air path for blockages
    F14 – Rear NTC Over Heating
    Check air flow
    Check cycling thermostat
    Check NTC (Aprx range 100K at 25C to 2.3K at 140C)
    F15 – Cooling NTC Overheating (Heat pump models)
    F18 – BPM Communication
    #103996
    don
    Sharp heat pump dryers. May be best viewed by mobile.
    Thanks to Lucasrangit 🙂
    #103997
    Hollytree_Technical
    These are the error codes for the new Hotpoint / Indesit Nucleus based washing machines.
    A Nucleus based machine can be identified in one of three ways:
    1. The parts list will specify Nucleus as the module type in the list and the exploded view.
    2. The service/serial number label has got a logo consisting of a black dot containing a white “N”
    3. The label on the module shows an atom logo.
    The Fault Codes are as follows:
    • F0 E5 = Unbalanced Load, (The 0 RPM speed is blinking together with the spin icon).
    • F1 E1 = Wash Heating Element Feedback Fault.
    • F3 E2 = Absence or out of range signal on frequency reading (linear pressure sensor only).
    • F3 E3 = NTC washing sensor failure (all).
    • F4 E2 = Wash heating element: relay short circuit / earth leakage.
    • F4 E3 = Wash heating element: relay open / wash heating element feedback pin short circuit with Vdc.
    • F4 E4 = Wash heating element earth leakage.
    • F5 E2 = Door lock fails to cloes, PTC door lock triac open, mains frequency signal fault, mains power signal fault.
    • F5 E3 = Door lock fails to open / IMP door lock triac short circuit / open circuit.
    • F6 E1 = HMI (“Human Machine Interface” – Display Board) not communicating.
    • F6 E2 = ACU not communicating with HMI (“Human Machine Interface”) or MCU (“Micro Control Unit”).
    • F6 E3 = No Communication between MCU (“Micro Control Unit”) and ACU (Main and motor control microprocessors).
    • F7 E1 = After 256 seconds motor stop not detected.
    • F7 E1 = Motor Tacho Failure (UM).
    • F7 E2 = MCU Fault.
    • F7 E8 = Motor Overheating.
    • F7 E9 = Motor not moving: Locked rotor or no signal from tachometer.
    • F7 EA = One motor phase disconnected during motor run.
    • F7 EC = Motor Overload.
    • F8 E1 = Warning H20 / missing water / tap closed, (The warning H20 [red tap] icon and F8E1 Fault are showed).
    • F8 E3 = Overflow.
    • F8 E6 = Aquastop / Water leakage detected.
    • F9 E1 = Pressure Switch empty condition not reached or drain pump jammed (valid for linear and status pressure switch).
    • F9 E2 = Drain pump electrical fault or Aquastop / water leakage detected.
    • FC E1 = Wifi module not communicating.
    A couple of issues that don’t display codes:
    • Door unlocking at start of cycle = Child protection routine – if the machine is not opened then the door should relock after a few seconds and continue the cycle.
    • Cycle stopping a few seconds after turn on = pressure sensor not connected.
    • Touch not working = Touch film damaged or not connected.
    To Activate Demo Mode:
    • Switch the machine On
    • Switch the machine Off
    • Press and Hold “Start/Pause” button for 5 seconds – a beep will confirm activation and if present the “Delicate” led will blink.
    • Within 2 seconds press “Power On” to run it.
    To Deactivate Demo Mode:
    • Press and hold “Start/Pause” button for 5 seconds – a beep will confirm deactivation.
    • Within 2 seconds press “Power On” to confirm it.
    Jem
