**KNOWN ERROR CODES**
Viewing 15 posts - 1 through 15 (of 151 total)
  • #4680
    Dave_Conway
    This could be quite a handy resource.
    If anyone knows error codes from any appliance please leave the details here.
    To do this, hit the reply button while viewing this message, change the subject to the Manufacturer and model number of the appliance concerned and list the error codes.
    Please don’t leave requests for codes here, ask for those directly in Technical Enquiries.
    This could build in to a very useful database.
    #103849
    NWAR
    LG WM1285FHD
    From Bryan Williams:
    LG Washing machines
    THIS FAULT IS’NT A FAULTITS TO TELL YOU THATTHE CHILD LOCK IS ACVITATED.
    YOU CAN DISENGAGE IT BY HOLDING DOWN THE FOLLOWING BUTTONS TEMP AND ECO/RAPID TOGETHER.
    THE FOLLOWING FAULT CODES AND MEANINGS IF ANYONE IS INTERESTED ARE
    OE = PUMP BLOCKED OR WATER NOT PUMPING OUT ( LOOK FOR A 5P IN THE PUMP IMPELLOR )
    IE = NO WATER INTO APPLIANCE CHECK WATER TAPS ECT
    DE = DOOR OPEN OR NOT LOCKED
    UE = IMBALANCED LOAD
    SE = NORMALLY MOTOR FAULT BUT COULD ALSO BE MAIN PCB FIRST CHOICE IS CHANGE MOTOR.
    CE = CURRENT ERROR SHORT CIRCUIT TO MOTOR OR MAIN PCB DUFF
    LE = MOTOR LOCK ERROR – HALL EFFECT SENSOR FAULTY
    FE = TO MUCH WATER IN TUB
    TE = TEMPRATURE ERROR NORMALLY THERMISISTER OR ELEMENT FAULT
    PE = PRESSURE SWITCH FAULT
    Lucky Goldstar
    #103850
    Hoover Error Codes:
    Here are some Hoover error codes, mainly for the New (now old!) Wave machines.
    E1 timed out either on fill, heat, or drain.
    E2 open circuit thermistor
    E4 motor current exeeded
    E5 motor tacho fault
    E7 motor windings open circuit
    #103851
    Smeg dishwasher error codes
    Here are some Smeg diswasher error codes for fully integrated dishashers with display. (Not the latest type)
    E2 over fill detected, more likely though it is not overfilling, just thinks it is.
    E3 not heating
    E4 thermister disconnected or o/c
    E5 no water fill
    E6 heating detected with no water present
    E7 not draining
    E8 read error, rest and try again
    E9 pause in test programme, not a fault code.
    #103852
    Servis Quartz error codes
    Servis Quartz error codes. I know its an old one but there are a few left, often kept going because of their smaller size.
    F1 water temp fault shows after wash prog
    F2 times out on fill
    F3 times out on drain
    F4 motor running to fast, too slow, or, most likely not at all.
    F5 heater fault (shows during wash prog
    #103853
    homersimpson
    The following are an explanation of specific error codes that may appear if there is a problem with a GDA washing machine, tumble dryer, dishwasher or refrigerator.
    Error Codes for hotpoint appliances,
    WASHING MACHINES & WASHER DRYERS
    E10 – No cold fill. Check that the taps are on or if the drain hoses are kinked.
    E11 – No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
    E12 – No mixed fill. It is likely that the water is not turned on at the taps.
    E13 – Check the water supply, inlet valve and hot and cold hose connections.
    E14 – A fault with the water heating has occurred.
    E15 – Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
    E16 – Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then book a service engineer.
    E17 – Door not closed properly. Close door firmly at the 3 o’clock position.
    E20/1 – The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing.
    E30/31 – A motor drive problem has occurred. Try running the programme again. If the problem persists book a service engineer.
    E40 – Water below protection level during a heat step.
    E41 – Water level detect sequence incorrect.
    E50/51 – Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language). Book a service engineer to re-programme your product.
    REFRIGERATORS
    E1 – Freezer thermistor open circuit.
    E2 – Freezer thermistor short circuit.
    E3 – Fridge thermistor open circuit.
    E4 – Fridge thermistor short circuit.
    E7 – Evaporator thermistor open circuit.
    E8 – Evaporator thermistor short circuit.
    E9 – Temperature set switch open circuit
    EA – No feedback from Baffle
    EB – Fridge Baffle motor operating continuously
    EE – Defrost time out
    DISHWASHERS
    E10 – Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
    E11 – Heater timed out. The heater has not reached the required level in a certain amount of time.
    E20 – Temperature under range. Book an engineer.
    E21 – Temperature over range. Book an engineer.
    TUMBLE DRYERS
    E1 – The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
    E2 – Thermistor or sensing circuit failure
    E3 – Heater plate over temperature. Check the filter and vent hose for a possible blockage.
    #103854
    AEG 72600 (1997) lavamat washing machine codes
    These are error codes for the AEG German made lavamat 1997 on.
    These are only guides as the position of the timer indicator should also be noted if any of these codes are shown, but at least it should point you in the right direction.
    C1 not filling/ too slow fill
    C2 not pumping/too slow pump output
    C3 Aqua control activated, either over fill or leak in base or open or short circuit pump.
    C7 Not heating or, oddly, leaking thru solonoid valve
    C8 dreaded NTC fault
    C9 Tacho or motor fault (brushes even)
    CA motor triac short circuit
    CD door lock faulty
    CE Water distributer fault (this machine has a small motor in the dispenser to select the compartment to fill through, this in turn operates a microswitch inside the dispenser. If this has not been activated within 2 mins, then this code is displayed*very common fault we find)
    CF double dreaded EEprom fault (ask Alex!)
    Some of these faults are locked in and will return even if machine is disconnected, the only way to clear them is to run the test programme. Hold in Pre wash and soak button while turning rotary knob to gentle spin.
    #103855
    Dave_Conway
    Here are the Hotpoint one’s from their website (worded for the public, but none the less quite helpfull).
    REFRIGERATORS
    TUMBLE DRYERS
    DISHWASHERS
    8)
    #103856
    bigkid
    Re: Known Error Codes
    Found this site with a list of error codes. May come in useful for you characters who live near American air bases … 😯
    http://www.repairclinic.com/0078.asp
    Tony
    #103857
    Dave_Conway
    Indesit Evolution Range
    Indesit Evolution Range Error Codes also refers to the number of flashes on the non-lcd type
    F01 Short Circuit-Motor Triac
    F02 Motor jammed or tachogenerator detached
    F03 Temp probe o/c or s/c
    F04 Pressure switch jammed on reset
    F05 Pressure switch jammed on trip
    F06 Programme selector management error
    F07 Heater relay stuck
    F08 Heater relay cannott be activated
    F09 Incompatable eeprom
    F10 Pressure switch not sensing correctly
    F11 Pump cannot be be activated.
    F12 LCD Display module and main module not communicating correctly.
    kindly supplied by Bonzaco:
    #103858
    Dave_Conway
    CDA VFU651T and Fagor dishwasher
    All four flashing is a door open fault.
    From left to right…
    2 lit/1 not/1 lit = Not filling
    2 lit/1 not = Overfilling
    1 lit/1not/2 lit = Control car, element or safety stat
    1 lit/1 not/1 lit/1 not = Temp control failure
    1lit/2 not/1 lit = Overheating
    1lit/3 not = Leak or inlet hose fault
    Courtesy of kwatt
    #103859
    Indesit WD late washer dryer eg WDE12.
    F13 dryer thermistor circuit fault.
    #103860
    DentedPorsche
    Whirlpool Dishwashers
    Whirlpool Dishwasher Error codes.
    F0. 10 flashes. Sensor Break (Only shown in test programme. Not visible to customer).
    F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
    F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
    F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
    F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
    F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
    F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
    Water Valve Closed. Water inlet hose blocked.
    Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
    F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
    F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
    F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
    FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
    FB. 12 Flashes. Motorised Diverter Valve
    FC. 13 Flashes. Water Hardness Sensor Failure
    A fault with no fault code indication = faulty module
    These codes should cover the entire range of Whirlpool dishwashers.
    Test Mode
    Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
    Open the door and set the program to the first program. (Normally rinse).
    Turn the power off.
    Press and hold the start button and while holding turn the power on.
    After a little while the start button will flash, release the button.
    Press the start button once and close the dishwasher door.
    The machine will now run through a diagnostic routine.
    If memory serves me right it takes about 20 mins.
    The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
    To exit diagnostics at any time just press and hold the start button till the programme is cancelled.
    #103861
    Dave_Conway
    Whirlpool Oven Codes
    F01 Open or short circuit temp probe Replace temp probe
    F02 Overheating of the oven Replace oven power unit
    F03 Oven power unit not configured Replace oven power unit
    F04 WISP protocol doesn’t work Replace oven power unit
    or hob control unit
    #103862
    Dave_Conway
    Whirlpool washing machine codes
    FH No water inlet
    FA Aquastop failure
    FP Drain failure
    F05 NTC failure
    F06 Tachometer failure (no motor movement detected)
    F07 Triac short circuit detection (motor control module)
    F09 Overflow
    F10 Motor control unit failure
    F11 Communication error (control unit)
    F13 Dispenser circuit error
    F14 EEPROM failure (control unit)
    F15 Motor control unit error
    F16+F18+F20+F21+F22 Control unit failure
    FDL Door lock error
    FDU Door unlock error
