Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › **KNOWN ERROR CODES**
- This topic has 150 replies, 56 voices, and was last updated 22 years, 9 months ago by
Dave_Conway.
September 6, 2011 at 5:45 pm #103968
ModeratorRe: **KNOWN ERROR CODES**
Hotpoint WML520/540,WDL520/BHWD/BHWM/WMF with progress lights on right of facia.
Indesit IWDC and IWB models.
Same for other recent models with this control panel setup and IWE with digital display.
All horizontal option lights will flash.
All VERTICAL error code lights are on steady, not flashing.
FAULT LED COMBINATION
These are numbered from BOTTOM to TOP, Door locked is led.1, Rinse is led.5.……..5….4…..3…..2…..1
F01 Off Off Off Off On
F02 Off Off Off On Off
F03 Off Off Off On On
F04 Off Off On Off Off
F05 Off Off On Off On
F06 Off Off On On Off
F07 Off Off On On On
F08 Off On Off Off Off
F09 Off On Off Off On
F10 Off On Off On Off
F11 Off On Off On On
F12 Off On On Off Off
F13 Off On On Off On
F14 Off On On On Off
F15 Off On On On On
F16 On Off Off Off Off
F17 On Off Off Off On
F18 On Off Off On Off
F01 Motor triac short circuit: Check motor and module connections
F02 Motor jammed / tacho detached: Check motor and module connections
F03 NTC short/open circuit: Check thermistor and module connections
F04 Pressure switch jammed on empty: Check switch and module
F05 Pressure switch jammed on full or pump blocked: Check pump and switch
F06 N/A
F07 Heater relay stuck: Check heater and module connections
F08 Heater relay stuck: Check pressure switch, heater and module connections
F09 Setup error: Check Eeprom
F10 Pressure switch not sensing: Check switch and module connections
F11 Pump cannot be activated: Check pump, connections and wiring
F12 No communication between cards: Check module connections
F13 High temperature Rise In Drying: Reduced air flow through dryer heater assembly.
Check operation of fan motor and dryer filter for blockage
F14 No Heat In Drying: Check one shot thermostat. Check heater, valve and fan
motor module connections. Edge connector J10
F15 No Drying: Possibly dryer relay open circuit
F16 N/A
F17 Door lock error: Check door, door lock and module connections
F18 Communication error (3 phase motor): Replace power boardOctober 25, 2011 at 2:46 pm #103969iadom
Hotpoint TCL tumble dryers.
Codes are same for digital display models such as TVF
All of the horizontal lights will flash and a combination of the right hand, vertical lights are on steady. Only the bottom five lights are used and are numbered from BOTTOM to TOP.
F01= 1
FO2= 2
F03= 1+2
FO4= 3
FO5= 1+3
F06= 2+3
FO7= 1+2+3
FO8= 4
FO9= 1+4
FO10= 2+4
F011= 1+2+4
FO12= 3+4
FO13= 1+3+4
FO14= 2+3+4
FO15= 1+2+3+4
FO16= 5
FO17= 1+5F01 The motor is running when it should be off.
• Check if module connector J3 has shorted due to moisture.
• Replace module.
F02 Open circuit between module and motor Common.
• Check security of module connector J3;
• Test motor Common (TOC);
• Check wiring between J3 and motor.
F03 Front thermistor open or short circuit.
• Check security of module connector J12;
• Test from connector pins (approximately 500 Kohms);
• If open or short circuit, test thermistor and wiring between thermistor and J12 to locate fault.
F04 Pump working when should be off.
• Check security of module connector J5;
• Check connector for signs of shorting due to moisture;
• Replace module (F04 would normally be caused by a faulty
module).
F05 Pump is not working when it
should be on.
• Replace module (F05 would normally be caused by a faulty
module).
F06 See post below from Martin.
F07 Lower element failure • Check security of module connector J4;
• Test between pins 4 and 3 on J4 (approximately 48 Ohms);
• If open circuit, test lower element and wiring between J4 and
the heater.
F08 Lower element is energised when it should be off.
• check connector for signs of shorting due to moisture;
• Test heater elements and wiring;
• Replace module (F08 would normally be caused by a faulty
module).
F09 Error Set Up File. Eeprom is either not programmed or is
not functioning.
• If the module is a production board, replace the module;
• If the module has an Eeprom socket, check the eeprom is
correctly inserted and programmed.
If testing for a Heater related fault, test on a Cotton High Heat setting or a Timed setting with High Heat enabled.
F10 Open circuit in the heater Common wiring.
• Check module connector J4;
• Check wiring between module connector J4 and the heater;
• Test heater elements.
Note: – Frequent cycling stat operation can cause F10, check
filter and condenser for blockages.
F11 Open circuit pump circuit. • Test continuity of pump;
• Check connector J5;
• Check wiring between pump and module J5.
Note: – F11 is usually caused by a fault in the pump circuit not
the module.
Auto cycle being used fault displays within 1 minute
Time and Wool cycles being used fault displays at the end of the cycle.
F12 No communication between display module and control module.
• Check connector J9 on module;
• Check wiring between module connector J9 and display;
• Check display connector;
• Replace module, display or wiring as required.
F13 Rear thermistor open or short circuit.
• Test from J4 connector pins 1 and 2 (approximately 500
Kohms);
• If open circuit, test thermistor and wiring between thermistor
and J4 to locate fault.
F14 Upper element failure • Check security of module connector J4;
• Test between pins 4 and 5 on J4 (approximately 48 ohms);
• If open circuit, test upper element and the wiring between J4
and the heater.
F15 Upper element is on when it should be off.
• Check heater elements and wiring;
• Replace module (F15 would normally be caused by a faulty
module).
F16 Not used.
F17 Master Relay contacts welded closed.
• Replace module.
a Timed setting with High Heat enabled.December 2, 2011 at 1:38 pm #103970RocketMan
ParticipantRe: **KNOWN ERROR CODES**
Whirpool Large (German made) 9KG AWM9000
Product Code 8570 084 15002
Probably also for the other 9KG range like the AWM8000F02 – pump/drain hose blockage
Does anyone have a full list for this series??
January 19, 2012 at 8:10 pm #103971loopey
no error code on indeshite or hotpoint dishwasers with no heat
will go through to end of program showing no fault code
built in or free standing usaull checks of heater and cabinet toc shoud be n/c . its the pcb every time
done around 9 this week
January 26, 2012 at 12:14 pm #103972Martin
Bosch WAE series Washing Machines
F16 Door Interlock problems
F17 Inlet Valve problems
F18 Drain Pump issues
F21 Motor troubles
F23 Anti-flood system activatedJanuary 30, 2012 at 11:45 pm #103973Steven
Amica dishwasher fault
E1 Longer inlet time(If the water valve is continue
working 4 minutes, the dishwasher will start E1
alarm)
E2 Longer drain time(If the drain pump is continue
working 4 minutes,the dishwasher will start E2
alarm)
Only for
pressure
switch
E3 Longer heating time(If the dishwasher heating over
60 minutes and not reaching required
temperature,the dishwasher will start E3 alarm )
E4 Overflow(If the overflow switch act,the dishwasher
will start E4 alarm)
E6 Failure of temperature sensor
E7 Failure of temperature sensor
Dry Rinse Main
E1 Flash X X
E2 X Flash X
E3 Flash Flash X
E4 X X Flash
E6 X Flash Flash
E7 Flash Flash Flash
Rapid Rinse Eco
E1 Flash X X
E2 X Flash X
E3 Flash Flash X
E4 X X Flash
E6 X Flash Flash
E7 Flash Flash FlashSoack Rapid Glass
E1 Flash X X
E2 X Flash X
E3 Flash Flash X
E4 X X Flash
E6 X Flash Flash
E7 Flash Flash FlashRapid Rinse Normal
E1 Flash X X
E2 X Flash X
E3 Flash Flash X
E4 X X Flash
E6 X Flash Flash
E7 Flash Flash Flash3IN1 Rapid Eco
E1 Flash X X
E2 X Flash X
E3 Flash Flash X
E4 X X Flash
E6 X Flash Flash
E7 Flash Flash FlashFebruary 13, 2012 at 10:54 am #103974bungy
Whirlpool Large Load Washing Machines
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
– Make sure that both valves at the water source(s) are turned on all the way.
– Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
– Verify inlet valve operation
• If there is water in the unit:
– Verify Drain pump operation
– Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation ***( Normally the FLOW METER)***
• Verify CCU operationF02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pumpF05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and RelayF06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire HarnessF07 Motor control unit error The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the MCU
• Check the Wire HarnessF09 Overflow condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
Potential Causes
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check for Drain Pump Failure
• Check the Inlet Valve for proper shut off
• Check the Pressure switch for proper operationF10 Motor Control Unit (MCU) heat sink thermal trip If the thermal protector on the MCU heat sink gets too hot, it will open the thermal protector on the heat sink which will stop motor functions and an F10 will be displayed.
Potential Causes
• Check for Proper Installation, verify the unit is not located near a source of heat and has proper ventilation.
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check MotorF11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check MCU
• Check CCU
• Check Motor
• Check Wire HarnessF13 Dispenser circuit error If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser MotorF14 EEPROM error The Central Control Unit (CCU) receives it’s data from an EEPROM onboard the CCU. If there is an error reading this data it will cause this error.
Potential Causes
• A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
• Check CCU.F15 Motor Control Unit (MCU) error If the MCU detects multiple resets or errors during a wash cycle it will go into this error mode.
Potential Causes
• Check Drive belt
• Check MCU
• Check Motor
• Check Wire HarnessSud SUDS LOCK (Overdose of detergent detected during the wash cycle) The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check Drain Pump
• Check the Pressure Switch
• Check CCUFdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly FailureFdU Door unlock error A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly FailureReplace failed component.
Note: The door lock/switch assembly can be manually unlocked.
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.March 20, 2012 at 10:27 pm #103975leavemetogetonwithit
I’m taking the liberty of copying and pasting one of Martin’s posts to here as I think it’s very relevant to Bosch error code problems and needs to be here so I can find it.
Re: Bosch WAE24363 Fault Code F21Postby Martin » Tue Mar 20, 2012 1:21 pm
mike412 wrote: went back to this machine today, F21 displays but thats it. None of the other buttons illuminate or have any action when operated.
Martin wrote:I found this old thread (and other similar ones on same subject) that need a little ‘clarification’ so to speak based on mike412’s findings.
With this type of machine that has ‘touch sensor’ control buttons it is necessary to isolate the motor (i.e unplug it) and reset the module before carrying out the repair. With the motor unplugged and the machine switched off at the selector switch. Holding any button and rotating the selector switch will re-establish the LED lights. Thus allowing full control of the buttons and you have fully ‘awakened the control module once again from its slumbers’.
Now replace the carbon brushes and job done!
Utilise the same technique for other error codes…. 😉
March 30, 2012 at 10:06 pm #103976Hollytree_Technical
Found these in the user manual:
Bush HW60-1460D
Error 1: Door Not Shut
Error 2: Drainage Error – Failed To Drain Within 6 Minutes
Error 3: Temperature Sensor Not Connected Or Damaged
Error 4: Heater Error (Shown At End Of Cycle)
Error 5: Water Level Not Met Within 8 Minutes
Error 6: Motor Heat Protector Error
Error 7: Motor Error
Error 8: Water Level Exceeds Protective Level
UNb: After Last Rinse Cycle Spin Fails Completely Due To Unbalanced LoadJem
May 17, 2012 at 9:04 am #103977Martin
Hotpoint/Indesit. (The missing error code!)
Courtesy of Iadom 😀
F06 (F6): –
Door lock fails to close / open, door lock PTC triac open/ closed, mains frequency signal fault, mains power signal fault.
– Check for water leaks that may affect connectors J004 or J11
(three-phase) causing the relative contacts to short;
– Check Door lock terminal board (any problems due to
aggression caused by manufacturing chemical residues that may
cause short circuits);
– Check J004 / door lock wiring;
– Check door lock;
– Renew PCB.June 7, 2012 at 6:15 pm #103978Martin
Participant**KNOWN ERROR CODES**
Bosch WAE series (without display)
Fault codes indicated by the vertical Spin Speed & Rinse Hold LED’s
1200 = LED1
1000 = LED2
800 = LED3
600= LED4
Rinse Hold = LED5LED1 = door fault
LED1 & 4 = drain fault
LED1 & 5 = fill fault
LED1,3 & 5 = motor fault
LED1,4 & 5 = heater fault
LED1,3,4 & 5 = base floodedJuly 29, 2012 at 6:28 pm #103979Allsorts
ParticipantRe: Known Error Codes
iadom wrote:Hotpoint DWT 10, DWF 50 & DWM55 also FDW/SDW60 dishwashers
Led 1 Intensive
Led 2 Normal
Led 3 Eco
Led 4 Fast
Led 5 Prewash
Led 6 Delicate3…..Overflow (water in base)-Leak from water line
4…..Solenoid valve fault -Inlet valve,connections
5…..Thermistor circuit-Thermistor c/w timer
6…..Timeout heating-NTC detached from casing
3+4.Timeout draining-Pump connections,blockage,module
4+5.Timeout filling-Tap off,Inlet valve,connections,timer,water turbine
3+5.Circulation pump not working- pump,connections,capacitor,module
3+5.Filters blocked-Mesh plate,filter or microfilter,pressure sensor
1+4.Software recognition error-Timer not programmed,wrong keypad
4+6.Heating circuit-heater,connections,module,relay
3+4.Hardware version (timer)January 22, 2013 at 7:22 pm #103980Martin
Hoover VHV series Tumble Dryers
Includes vented and condenser versions. Those without display count the number of flashes (e.g 9 flashes = E 9)
E 3 Water Tank full
E 4 Programmer Selector faulty
E 5 Front NTC faulty
E 6 Reprogram or replace main board
E 7 Clean lint filter or airflow problem
E 8 Thermal fuse
E 9 Thermal cut out
E10 Missing load
E 14 Rear NTC
E 15 Heater Relay or (for vented dryers) Open circuit front TOCFebruary 2, 2013 at 11:22 am #103981Martin
Hoover/Candy series with LCD screeen
E:01 = Door Interlock and/or triac on PCB
E:02 = Fill time-out, faulty inlet valve
E:03 = Drain time-out, pump faulty, blocked filter etc
E:04 = Anti-flood, pressure switch level tripped
E:05 = NTC
E:06 = Unbalance problem (only readable with MEM software)
E:07 = Door interlock closed
E:08 = Motor Tacho
E:09 = Motor triac on PCB
E:11 = Dryer NTC
E:12 = Dryer Module
E:13 = Main PCB failure
E:14 = Water heating fault (Heater or NTC)
E:15 = Main PCB not programmed
E:16 = Water heater short circuit
E:17 = Wrong signal from Tacho
E:18 = Faulty main PCBFebruary 15, 2013 at 10:02 am #103982Martin
Electrolux “Talking” Dishwasher includes some Zanussi and AEG models.
i10 = Fill time-out
i20 = Drain time- out
i30 = Anti-flood device
i50 = Motor triac
i60 = Overheating/heating time-out
i70 = NTC short circuit/open circuit
i80 = EEPROM
i90 = Wrongly configured
iA0 = Top spray arm blocked
ib0 = Turbidity sensor
id0 = Circl. Pump tacho
iF0 = Water top up failure
i 0 = No alarm stored -
