Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Leisure Cookmaster 100 – CM10FRC
- This topic has 55 replies, 13 voices, and was last updated 14 years, 10 months ago by
HeilNerbert.
May 28, 2011 at 2:42 pm #63070
HeilNerbert
ParticipantGood afternoon,
I have recently had an issue whereby the fan oven and clock have stopped working. Like me you felt this could be clock related as all other electrics work fine. I have just purchased part number EL145/280.121 from you and just finished installing. However still no joy with oven or clock. I have noticed that the original clock part number is EL145/280.64A.
Do you think the replacement part I ordered is not compatible?
Thanks.
Regards,May 28, 2011 at 7:19 pm #352416kwatt
KeymasterRe: Leisure Cookmaster 100 – CM10FRC
Did you check the oven safety thermostat, this part was okay? They have a nasty habit of failing and cause symptoms like that to manifest.
The clock will be fine, it’ll just be an update. Work off the part number and not the production numbers on the part itself as they do change over time quite often.
May 28, 2011 at 9:55 pm #352417HeilNerbert
ParticipantRe: Leisure Cookmaster 100 – CM10FRC
Thanks K,
No, I haven’t checked this part, wish I had as looks a lot cheaper than the clock.
Regards,May 29, 2011 at 10:32 pm #352418HeilNerbert
Hello,
Just ordered the thermostat, so will let you know how I get on, before anyone else makes the expensive mistake of taking the advice of changing the clock first.
Regards,June 4, 2011 at 1:13 pm #352419HeilNerbert
Help,
As mentioned previously the the clock was not the issue, so I have now purchased the thermostat you have suggested. However I cannot find where this is located. I have the back and top off the cooker and there is no part that resembles the thermostat. In the fan oven there is a wire located next to the fan which runs up to the fan oven control.
Please could you help?June 4, 2011 at 1:17 pm #352420kwatt
They’re usually mounted on the rear of the oven cavity or on the top of it.
HTH
June 4, 2011 at 1:25 pm #352421HeilNerbert
Thanks K, I’ll take another look. The thermostat on the fan oven looks like this part, 263100016 – Beko Oven Thermostat.
Is the safety thermostat part definately in this model?
Regards,June 4, 2011 at 1:37 pm #352422HeilNerbert
The only electrical parts on the back of the oven are the light, fan, element and thermostat wire. Above the fan oven is the grill and no wires appear to run there. Are you sure you are looking at the correct model oven?
June 4, 2011 at 2:03 pm #352423HeilNerbert
Help,
Any ideas guys as very keen to get this fixed or at least get oven put back together and put back.
Regards,June 4, 2011 at 2:04 pm #352424kwatt
Yes, it’s definitely listed as being used in that model.
I’m trying to get on the system to see where it’s fitted but I’ve not used it outside the office before now. 😉
June 4, 2011 at 3:00 pm #352425kwatt
Okay then, this is good stuff…
Attached here is what we see when we look up these parts…
And there is a note on these cut outs that shows and stresses that they must be correctly fitted or the fault will reoccur, pictures even for a change…
That’s as much info as I can give you other than that, yes, it is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain that the thermal cut out is fitted on that cooker.
HTH
June 4, 2011 at 3:16 pm #352426HeilNerbert
Thanks for the effort and the pictures. Looks like my model differs slightly as the part certainly is not where the photo shows.
Looks like I need to call out an engineer.
Regards,June 4, 2011 at 3:22 pm #352427kwatt
Did you buy the part from UKW?
I ask because, on the product page there’s those pics and also a photo of how the original one looked as it’s been changed.
If you didn’t buy from us and just went off Googling the part number to get the lowest price on the planet you probably didn’t get all the info. 😉
June 4, 2011 at 3:49 pm #352428HeilNerbert
The part I purchased was not from UKW. You gave me the link to the correct part which I did search for on the internet and did source cheaper, having just purchased the clock from UKW, for nearly £60, which didn’t fix the problem as suggested.
My father in law has just taken a look with me and this part is not located where the photo shows. I have also taken the back off the conventional oven and it is not there either. I can only guess that this part is located somewhere under the hob, doesn’t exist on my oven or is a different part.
Regards,June 4, 2011 at 6:52 pm #352429kwatt
The original one doesn’t look the same as shown in the first photo at the bottom.
