Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Leisure Cookmaster 100 – CM10FRC
- This topic has 55 replies, 13 voices, and was last updated 14 years, 10 months ago by
HeilNerbert.
December 29, 2011 at 10:14 pm #352460
csmith
ParticipantRe: Leisure Cookmaster 100 – CM10FRC
ok thanks for that. I’ll have another look tomorrow and get back to you if I get stuck.
CheersOctober 9, 2012 at 2:44 pm #352461Tabs_baby123
Hello
Having read this forum we purchased the thermostat part as we are having the same issue with our Cookmaster 100 CM 10 FRC. However the pictures you show do not match the back of our oven and we cannot locate where this part is on the oven.
Please can you advise where it could possibly be or provide other pictures?
We live in France so we cannot call an engineer so are trying to fit this ourselves.
Many Thanks
EllaOctober 9, 2012 at 3:40 pm #352462kwatt
KeymasterRe: Leisure Cookmaster 100 – CM10FRC
If you read back I think that these were changed and the new bears little to no resemblance to the new one.
November 18, 2013 at 12:21 pm #352463cookleyman
I have a Leisure CM10frc with no fan oven or clock display. I have replaced the clock but still have the same problem. From these posts I went looking for a stat but could only find something that looks like an inline fuse on a continuous brown wire which is open circuit. There is also one on the non fan oven with which I get a continuous reading. What is the part number I need to order for this. Thanks
November 18, 2013 at 12:36 pm #352464kwatt
The original one was an inline fuse type if my memory serves, the later version being this one…
http://shop.ukwhitegoods.co.uk/21011054 … thermostat
January 14, 2014 at 10:37 pm #352465flumpet
I just want to say a big THANK YOU!! 🙂
I’ve had this problem with my CM10FRC for a couple of years (clock & fan oven not working), but didn’t do anything as was happy to use just the one oven.
I read about the clock problem, but decided to try this first.
BRILLIANT – yes a little complicated as the fuse is a wire in a sheath & the replacement from UKW came in pieces and didn’t fit exactly like the photos… BUT, it’s wired up now and the clock & fan oven works!! 🙂
I can now set my cooker to cook my tea and be ready for me when I get home from work instead of having to wait 🙂 🙂
Thank you again – you’ve saved me so much money, time & effort.
December 17, 2016 at 4:16 pm #352466Nicholiath
I have ordered the updated thermal fuse for the leisure oven cm10frc.
I have an older oven so which wires do I connect to the new fuse please?September 1, 2018 at 10:41 am #352467Firekarter
I have just received the same and have the older oven
The new part has 3 connection any idea where they go?
ThanksSeptember 1, 2018 at 10:59 am #352468electrofix
ModeratorRe: Leisure Cookmaster 100 – CM10FRC
if you are talking about the same thing as above
and it only has 2 connection not 3
so not sure what u mean
what part number have you got ?
September 1, 2018 at 2:51 pm #352469Firekarter
Hi Dave
Yes I have the part in link.
It has two black connections which I gather connect to fuse.
One lead has a connector on end the other lead splits into two at the end.September 1, 2018 at 4:17 pm #352470electrofix
It will be a universal kit to do a number of cookers some may use the double link some may not. Just follow what exists on original fuse
