Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Leisure Cookmaster 100 – CM10FRC
- This topic has 55 replies, 13 voices, and was last updated 14 years, 10 months ago by
HeilNerbert.
June 5, 2011 at 11:58 am #352430
HeilNerbert
ParticipantRe: Leisure Cookmaster 100 – CM10FRC
K,
The first photo at the bottom appears to show something attached to the outside back of the oven itself. The following photo’s are showing the cut out attached to a bracket. As mentioned previously, the only electrical connections on the back of my fan oven are the fan, light and element. All of the wires in the wiring loom, which are shown in the photo’s, are solid on my oven and do not have any breaks with connectors.
This part certainly does not appear to exist on my model, on either oven, or is located in a completely different place. Very stuck.June 5, 2011 at 3:27 pm #352431kwatt
KeymasterRe: Leisure Cookmaster 100 – CM10FRC
It is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} listed for that model and there is a safety fitted.
Item 477 on the blowout. Looks like a little square under the controls. Listed on the Beko system (who make it) as: 477 – 210110544 – THERMAL CUT-OUT+SHEET+SCREW GROUP
It did look like this.
June 5, 2011 at 4:14 pm #352432HeilNerbert
Thanks K,
Still a bit dubious as the description doesn’t mention my model oven, plus says for small/top oven. In the mean time I have contacted Leisure, so will let you know how I get on. If I get to pull the oven out again this week I’ll check out part 477.
Regards,June 6, 2011 at 5:57 pm #352433Washman
Where the picture in the above post shows the new style stat is there a wire clamped to that bracket, the original stat is no longer avaliable. You just cut out the original and replace with the new one and new crimp on terminals.
Turn off power first.
Washman
June 7, 2011 at 11:54 am #352434HeilNerbert
Thanks Washman for clearing things up.
Yes, there is a brown continuous wire which is clamped to a metal plate. I’ll get some crimp on terminals and give it a go.
Regards,June 12, 2011 at 1:46 pm #352435HeilNerbert
K/Washman, thanks for all the help. Just replaced the cut out and all working fine. I’m sure we could have got there quicker, but all sorted now.
Shame that I tried the clock first as suggested as what was actually a £4 job has cost £60. Still I do have a spare clock now and there is always ebay, unless anyone else needs one.
Thanks again.
Regards,July 21, 2011 at 10:20 am #352436Daniel140280
HELP PLEASE. On a similar theme, well cooker actually, my main oven on the Leisure Cookmaster 100 has stopped working. It happened following a recent power cut, whilst the oven was in use. When power was restored and the oven turned on again, both the light and fan come on but no heat is observed. Has a fuse or element (guessing here) blown? Is there a way to check and resolve? Thanks, Daniel
July 21, 2011 at 10:46 am #352437kwatt
Hi Daniel,
That sounds like an element failure but, you’d have to check it.
Also if you can give me the full model number I’ll be able to tell you what element is in the cooker and whether there are any cheap alternatives available.
July 21, 2011 at 12:46 pm #352438Daniel140280
Thanks K.
Its the Leisure Cookmaster 100, model number is either CM10FRC-CM10FRK, CM10FRCP-CM10FRKP or CM10BRC-CM10BRK. I can’t see in the manual the differentiations. It’s a dual fuel cooker with eletric ovens. Does this help?
How can I check if it is the element? Any tips would be appreciated thanks.
Daniel
July 21, 2011 at 1:05 pm #352439kwatt
Hi Daniel,
The original fan element is this one:
There is a cheap compatible alternative available as well though, this one:
It is most probable from what you’ve described that that’s what’s gone wrong as if it was the safety stat then you wouldn’t get the fan or oven lamp on if I recall correctly.
HTH
July 21, 2011 at 1:35 pm #352440Daniel140280
Thanks K.
Is this a relatively easy thing to replace. I’m hoping from some pictures I’ve seen that I can access this from the inside of the oven (without pulling it out), and simply replace, or am I being a bit simplistic with this hope.
Thanks,
Daniel
July 21, 2011 at 1:38 pm #352441kwatt
Hi Daniel,
No from memory you should be able to do that without moving the cooker.
You need to get the back panel off the back of the back wall of the oven, there will be a couple of screws or nuts and the panel will just lift out. Behind that sits the element and it’s normally just held there with two screws and a clip.
There’s more help on this sort of stuff in this article:
http://www.ukwhitegoods.co.uk/help/fix- … notes.html
HTH
July 21, 2011 at 2:14 pm #352442Daniel140280
Many thanks K. I’ll take a look tonight and then get some parts ordered to fix it, hopefully!
July 27, 2011 at 9:59 pm #352443Daniel140280
I’ve received the part now, but when looking to remove the element it looks like the screws come through the back?! Is this correct or should that always be attached from the front? I took some pictures if it is possible to upload for confirmation.
Does it look like I need to pull the oven out to release screws?
Thanks,
Daniel
July 27, 2011 at 10:36 pm #352444kwatt
If the element is screwed from the back it’d be very odd.
If you mail me the pictures I can have a look or upload them.
