Necht Dishwasher
Viewing 15 posts - 31 through 45 (of 62 total)
  • #118830
    Re: Necht Dishwasher
    Thanks for the reply. We tried that and the water is cold.
    When we put i the auto reset theom, it worked for the first wash and we have not been able to get it to do a full wash again. It appears that the water is not heating at all. 😕
    Dennis
    #118831
    Dave_Conway
    There is an underlying cause to the problem I believe.
    Please check repairs@ and the diectories for an engineer to check the dishwasher and hopefully repair for you.
    #118832
    I have a Necht dishwasher WP12-6015 3 months old, it went up in flames yesterday. Upon removal, I took the door off & the fire centred around the door switch. I cant get hold of Necht on the phone number in the manual, is there another way to contact them, I want the machine replaced. Thanks for any info
    Colin
    #118833
    Dave_Conway
    The Necht brand name is owned by Maple Industries, the dishwasher itself is manufactured by Haier.
    It’s likely the dishwasher came with the kitchen as part of a package.
    MAPLE INDUSTRIES LTD
    Maple Mill
    Cardwell Street
    Oldham
    OL8 2AG
    England
    Telephone: 0161 622 3252
    Fax: 0161 622 3280
    Necht Domestic Appliances Service
    Maple Mill/Cardwell St
    Oldham
    OL8 2AG
    Telephone: 0161-622 3259
    Hope that helps.
    #118834
    Sonia
    Necht Dishwasher
    hi kheath
    we’ve just bought and installed a Necht WQP12-9319 dishwasher, the first time we’ve used it it started and then beeped and stopped displaying an E2 error. Do you know what that is?
    SOnia
    #118835
    There’s a couple of faults that can give the same symptons…..
    Check,
    1) water valve under the sink is on and as far as you can determine that the hose has not got a kink in it.
    2) oversudsing because of 3 in 1 tablets used with rinse aid ( yes it will happen that quickly)
    Either of these can throw E2….however you are covered “in guarantee” and should contact your installer or Necht(see Dave’s post above) for service.
    These dishwashers are not bad, yes they have the problem of oversudsing, causing the heater stat to trip out, but once you are aware of it and use the detergents correctly it should settle down and give you good service.
    Plenty of manufacturers have this same problem, one day we’ll have a tablet we can reccommend to use as a detergent which won’t trigger this fault. 😉
    Kevin
    #118836
    Sonia
    Thanks kheath
    I’ll check that!!!
    Sonia
    kheath wrote:Hi
    Check,
    Kevin
    #118837
    alana
    hiya
    we have had our dishwasher about 4 months…
    its a necht wqp 12-9319…
    it been working pretty well with finish powder but
    now we have got an E3 in the display with a noise
    comin fron the bottom…
    any ideas please
    thanks
    Alana
    #118838
    No drain in the time allowed. Is it empty? The noise may well be the drain pump running continuously. By the same token, if the drain pump is running continuously, the base may be flooded. So, find the blockage or find the leak.
    Power off if investigating or click the link below for some pro help.
    alana
    Thanks for replying, you were right there was a blockage in the pipe leading from the dishwasher to the drain, got rid of it , now working great….
    Thanks very much
    youre a life saver !!!!!!
    alana
    #118840
    Ravn1
    I have had a Necht WQP12-6015 since August 2004, after a couple of months the thermostat went & was replaced under warranty. Now, last week, the main on-off button has stuck in & a fire nearly started in the door. I cannot reach Necht on their customer services number (0161) 622 3259 – Any ideas whether they are still trading? Also, I have tried to find an engineer through this site – I did not get a reply!
    #118841
    helaine
    we also have a necht and have tried to follow the instructions to re set it but having taken the back off we cant find the reset button, no one knows how to fix it i have called everyone in the basingstoke area but no luck, i have tried to call the necht people but get no answer, our problem is the same as previous post, the cycle stops mid way through the water is cold and there are 2 lights flashing on the control pannel….please can someone help !!!!
    #118842
    Dave_Conway
    If you use the search function here:
    http://www.ukwhitegoods.co.uk/modules.p … ile=search
    And search for necht and/or haier you should find the answer as it’s a common problem 🙂
    #118843
    helaine
    thanks dave will try that, although i am now contemplating going out and buying a new dishwasher !!!!
    #118844
    alana
    Hiya
    Ma again.!!!
    I have a Necht wqp 12-9319…
    I had an E4 flashing on my dishwasher, thats gone now i
    only got the time whch is going up and
    down on its own. The programmes buttons cant be moved!!!
    Please help i HATE washing dishes lol
    thanks
    Alana
