Necht Dishwasher
Viewing 15 posts - 46 through 60 (of 62 total)
  • #118845
    Lozzy
    Re: Necht Dishwasher
    I have recently moved into a house with a Necht WQP12-9319 dishwasher.
    When I switch it on the display says “18” and none of the grey function buttons respond. esp the program button and corresponding lights (none of which are illuminated).
    Needless to say – nothing else happens. Seems to be stuck like this.
    Previous owners not very helpful.
    It’s fitted into the work surface so I’m trying to avoid using the reset switch. Could be destructive!
    Any help would be greatly appreciated.
    Lawrence
    #118846
    JungleJme
    DO NOT BUY FROM NECHT OR MAPLE INDUSTRIES. THE GUY WHO RUNS IT IS A RIP OFF MERCHANT (Vince Miller), HAS BEEN ON WATCHDOG AND BEEN ISSUED WITH A STOP TRADING ORDER IN THE PAST.
    PRODUCTS HAVE BEEN KNOWN TO EXPLODE & IGNITE! DO NOT APPROACH!
    #118847
    metalmagpie
    😥 My Necht WQP8 9325, Shows a E4 fault just after being switched on. It doesn’t appear to be the level switch, I thought this as the drain pump runs for a short period then stops. Any help woulod be appreciated as the guarantee ran out last week!
    #118848
    Base flooded as usual. Unplug it and tip it back to reset.
    mrking
    i have an out of gtee necht wqp12-9319 whcich has an error code E3
    displaying it seems to start ok but the water isn’t heating up but it drains ok
    we have been using 3in1 tablets so from what i have read this could be a cause. not sure about the reseting suggestion i have seen on this site would this help? any suggestion would be appreciated
    cheers
    #118850
    Reset procedures found in these forums generally refer to SMEG-built appliances. Yours, sadly, is a Haier or “Little Swan”, from China. Spectacular failure rates……..
    Right – 3 in 1 tablets froth badly, foam has rather different thermal properties compared with water and an overheat situation on the element will happen. This should, in theory, trip out the safety thermostat on the underside of the machine. spares@ukwhitegoods.co.uk will be able to source you a replacement. If you are unlucky, the element many have failed as well. You will need to use a test meter to find out for certain.
    If you are not sure how to proceed, use the repairs@ link below to find a UKW repairer in your area.
    Power off, if you intend to investigate this yourself.
    mrking
    thanks for the reply i will try and find the reset switch first (going of previous post) and test the heater also any other tips would be welcome
    thanks
    Penguin45 wrote:Reset procedures found in these forums generally refer to SMEG-built appliances. Yours, sadly, is a Haier or “Little Swan”, from China. Spectacular failure rates……..
    mrking
    no luck finding the reset switch on my dishwasher i belive you can’t get parts for this thing so no point calling anyone out is it time for the skip?
    i do have photos with back off but still getting E3 error
    #118853
    It isn’t a re-set switch, it’s a safety cut-out – single use only. Pictures of the back won’t help – if you can get one of the underside, we might be able offer some pointers. We can get parts – this machine appears under numerous different badges, so we can usually find parts from somewhere. Use a link from Photobucket or similar to post.
    mrking
    hi penguin
    thanks for the help i have a few pictures to sart with will do the under neath tommorow hopefully
    http://s195.photobucket.com/albums/z252/thewelder06/
    hope link works
    #118855
    The brass/black plastic lump in the top left piccie is the safety.
    mrking
    great news now all i need is a spare part, i have an large appliance spares shop near me called bec components i will try them on sat
    see if they can help is there any technical info i can give them to obtain the right part or should i try elsewhere, reading other posts a replacment exists ?
    many thanks so far
    chris
    Penguin45 wrote:The brass/black plastic lump in the top left piccie is the safety.
    Not Bekelec in Otley……….?
    Have you stuck the test meter across the terminals to check for continuity? Don’t spend ’til you know – expensive way of repairing an appliance.
    :p45:
    #118858
    Penguin45 wrote:Not Bekelec in Otley……….?
    :p45:
    Possibly BEC near Stockport, mrking appears to be a local Ntl/Virgin customer on the Baguley super headend. 😉
    http://www.bec-components.co.uk/
    mrking
    went to bec components they couldn’t help so now i am stuck
    i have read in previous post there is a replacement part that no one has been able to provide as yet. hope the picture will help
