Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Necht Dishwasher
- This topic has 61 replies, 16 voices, and was last updated 21 years, 5 months ago by
shanz.
October 28, 2004 at 12:43 pm #6646
shanz
ParticipantHi all,
I have a Necht dishwasher that keeps tripping halfway through a cycle.
I have been shown how to reset the DW by pressing the button at the back of the appliance but how can I stop it happening all the time.
Is it a faulty thermostat or is the water temp too high ??
Please help
Cheers
Shanz
October 28, 2004 at 1:06 pm #118801Dave_Conway
ParticipantRe: Necht Dishwasher
Shanz, can you post the model and serial numbers please.
Necht don’t actually manufacture these appliances, they are rebadged.
Regards.
October 28, 2004 at 1:07 pm #118802shanz
ParticipantThanksDave,
I will find out this info tonight and let you know.
Cheers
Shanz
November 1, 2004 at 9:59 am #118803shanz
ParticipantDave,
Sorry for the delay but here is the Model No and Serial No of the Necht Dishwasher.
Model – 11714
Serial No – 6015200307170Many Thanks
Shanz
November 1, 2004 at 1:08 pm #118804Dave_Conway
Shanz, are you sure that’s the model (I’m not doubting you) but there may be another number begining with WQP or similar.
I have no reference for 11714
November 1, 2004 at 1:13 pm #118805shanz
ParticipantCheers Dave,
I messed up.
The Model No is WQP 12-6015
and the S/N is 601520030717011714Thanks
Shanz
November 1, 2004 at 3:09 pm #118806Dave_Conway
That’s a Haier then.
You’re not using 3 in 1 tablets by any chance are you Shanz ?
November 1, 2004 at 3:11 pm #118807shanz
ParticipantLOL,
I am not sure whether they are 3 in 1 tabs, why?
Shanz
November 1, 2004 at 3:55 pm #118808Dave_Conway
They tend to cause excessive foaming which makes the heating element get too hot causing nuisance tripping of the safety thermostat.
If they are tablets it will almost certainly be the 3 in 1 type.
Try using powder and a seperate rinse aid and see what happens.
DAve.
November 1, 2004 at 4:03 pm #118809shanz
ParticipantLOL,
That’s cool.
I’ll give it a go, but you’d expect the dishwasher manufacturers to have tested the machine with these tablets in the first place.
Is there another tablet type that I can use or am I stuck with using powder???
Thanks Dave
Shanz
November 1, 2004 at 4:19 pm #118810Dave_Conway
Stick with powder 😉
November 1, 2004 at 9:33 pm #118811admin
KeymasterRe: Necht Dishwasher
This is a current problem with these dishwashers and a new stat is available which is self reseting. The TOC is only rated at 78 degrees 10amp at 250volts….and trips out regulary. Try to speak to your supplier about the new stats and get one fitted.
The carlton slimline is the same appliance and also suffers the same problem, don’t change the bank of 3 stats(its a pain) as this won’t cure the problem. Unfortunately Carlton don’t seem to be able to supply a modified stat.
There is no part number for the modified stat but are sent foc to agents for use on Necht appliances. We replace this stat whenever we attend a Necht regardless of fault.
Kevin
November 2, 2004 at 9:55 am #118812shanz
ParticipantKevin,
Thanks for your help.
If I could get hold of one of the modified stats, would I be able to replace it myself?
i.e. is it easy enough to change, do I need any special tools etc?
Cheers
Shanz
November 2, 2004 at 9:22 pm #118813admin
send me a pm with your address and i’ll forward one to you..for free.
kevin
ps…please don’t swamp me with request for the stats i don’t have have the stock holding.November 11, 2004 at 12:53 pm #118814shanz
ParticipantKevin,
Been away for a few days and just wanted to say thanks you for the stat that you sent me for the Necht dishwasher.
Is it easy to replace?
i.e. Where is the stat actually located in the dishwasher?
Just want to get an idea before I start opening it up.Cheers again
