Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › NEF U1721 double oven
- This topic has 59 replies, 3 voices, and was last updated 5 years, 5 months ago by
vidmarc.
October 12, 2020 at 5:49 pm #98471
vidmarc
ParticipantThe main fan assisted bottom oven isn’t heating up, all I’m getting is cold fan air. Any suggestions? Thanks.
No jacket potato for me this evening 🙁October 12, 2020 at 6:06 pm #472482don
Moderator90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} + of the time it’s the fan oven element that has failed. It looks like it’s this There are five different versions of your oven chances are they all take the same element but to make sure can post up the rest of the ENR no.
Don
October 13, 2020 at 11:04 am #472483vidmarc
ParticipantThanks Don. The E-Nr on the front side of the oven reads: U1721N2GB. /05. FD 8405
October 13, 2020 at 11:19 am #472484electrofix
Moderatorpart number of element 494643
https://shop.ukwhitegoods.co.uk/4946…n-oven-element
dont use non gen elements on these as i have had problems over the years
its a bit of a pig to get off as you have to remove the fan to get at the centre screw and some are real fun to get them off
for your interest unit built may 2004
October 13, 2020 at 11:24 am #472485vidmarc
ParticipantThanks – is this something I can replace myself, or is it an engineer’s job?
October 13, 2020 at 11:45 am #472486electrofix
Moderatorall depends how easy that fan comes off
unless your good with mechanics and removing siezed parts then its an engineers job. Dont forget its been on there for 16 years or so
try here
https://www.ukwhitegoods.co.uk/search/find-an-appliance-engineerinsist on a gen element
October 13, 2020 at 11:52 am #472487vidmarc
ParticipantI did train as a mechanical engineer back in the early 80s, so I’ll give it a try 🙂
Is there some sort of guide as to taking it apart etc?
October 13, 2020 at 12:01 pm #472488electrofix
ModeratorI remove inner cover plate. early ones use philips screws later ones use torx 20
undo nut on fan and remove washer behind
after that fan pulls straight off but its seldom that easy
you can add a but of wd but the oven will stink of it till it burns off. Also remember its flammable so use a little in the right place
i then jam spanners behind the fan so its solid. take the original nut, screw it back on but not all the way. Then using a socket and extension i tap the extension with my pliers. what your trying to do it push the shaft through the fan which cant move because its jammed against the back of the oven. as it comes off you will have to back the nut off to get it further and further. the last but can be hard as you dont want to damage the motor shaft as the gen ones are over £100
you never know, Some fall off and some are real pigs
when you come to put it back make sure the orientation is correct as the “d” in the washer has to be in correct position
October 13, 2020 at 2:13 pm #472489vidmarc
ParticipantThanks Dave, you’re a star 🙂
I’ve just had a look at the current element and it actually looks fine. I was expecting it to look like it had blown in some way – what causes them to go?October 13, 2020 at 2:19 pm #472490electrofix
Moderatorthey normally blow on the curves as they turn 90 degrees as they go through the back panel
these elements were a bit of a problem and did not seem to last as long as the circular ones
October 13, 2020 at 3:11 pm #472491vidmarc
ParticipantYou’re absolutely right, that nut is difficult to undo. Do you know what wrench size it is?
October 13, 2020 at 7:22 pm #472492electrofix
Moderatorit might be 10mm but cant remember but it may be a left hand thread
October 13, 2020 at 7:31 pm #472493vidmarc
ParticipantHmm, so it’s possible I’ve been tightening it? 🙂
October 13, 2020 at 8:05 pm #472494electrofix
Moderatorwhich ever way the fan turns the nut undoes in the same direction ( most of the time )
October 14, 2020 at 1:21 pm #472495vidmarc
ParticipantI managed to bend the top bracket instead of removing the fan, which seemed impossible.
