NEF U1721 double oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum NEF U1721 double oven
Viewing 15 posts - 16 through 30 (of 60 total)
  • #472496
    vidmarc
    ps – I still can’t see anything visibly wrong with the old element. Anyway, new element ordered. 🙂
    #472497
    vidmarc
    Thaanks so much for your help, managed to get the fan out, fittted the the new element and it’s working perfectly again. 🙂
    #472498
    vidmarc
    Four years later – Bottom main oven has just stopped working again. No fan and no heat. Same thing, or perhaps something else?
    #472499
    if its got a clock check that first
    it would only be the element if the fan was running
    vidmarc
    The clock is fine, I fiddled about with it and the timer isn’t set. There’s no fan or heat. The top oven/grill works fine.
    #472501
    vidmarc
    When I switch the main (lower) oven on, I can hear a humming sound comming from inside, but as I said the fan and main oven itself appear to be dead.
    #472502
    ok first off remove the inner cover and see if the inner fan is turning by hand
    vidmarc
    That was my initial thought. Is it held in place by torx screws or similar? I’ll have a look tomorrow.
    #472504
    yes they are torx 20
    vidmarc
    I have had to order a Torx driver as I can’t find the set I had. It does appear that the fan is stuck, I tried turning it through the grill, but it doesn’t seem to move freely. Would this cause the oven not to heat up?
    #472506
    if the fan has stuck it will heat but all the heat will rise
    but with these oven the elements were always trouble so it possible the element has distorted and jammed the fan
    as or the torx driver Aldi and Lidl often have sets
    vidmarc
    The fan appears to be rubbing against something behind it and doesn’t move too easily. What could have caused this to happen? So could the element and the fan be kaput? Might be time for a new oven I guess.
    #472508
    vidmarc
    Right, after another look it seems the top screw behind the fan has worked its way loose, and it’s stopping the free movement of the fan.
    But even if I re-tighten the top screw to enable the fan to spin, it seems the element may have died after fitting a new one just a few years ago?
    #472509
    vidmarc
    Update – screw tightened, fan now working again. But element is indeed not heating.
    #472510
    yes these were always a pain. changed lots of them and a real pig of a job
    Element will have over heated with fan not turning
