Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › NEF U1721 double oven
- This topic has 59 replies, 3 voices, and was last updated 5 years, 5 months ago by
vidmarc.
November 15, 2024 at 1:47 pm #472511
vidmarc
ParticipantI’ve encountered a slight problem – one of the clips that attaches to the element itself seems to have broken , and it won’t stay firmly on the element clip. Any suggestions? The wire itself seems to be slightly shorter than the other cable, and I’m worried it might drop back through the hole.
November 15, 2024 at 2:02 pm #472512electrofix
Moderatorall you can do is gently squeeze the terminal with pliers to tighten it. if it loosens again then the metal may have degraded and it would need a new terminal fitted. if its left loose it will burn out and you may have to replace the element again as it will damage that terminal as well
DaveNovember 15, 2024 at 2:45 pm #472513vidmarc
ParticipantIt seems to have badly corroded. I squeeze it together with pliers, but will not stay tight enough to remain securely connected. I don’t trut using it as it will most likely come loose and short out with the nearby pin. Can I buy new spade connector clips somewhere?
November 15, 2024 at 2:46 pm #472514vidmarc
ParticipantOr is there some way of extending the cable with a cable joint and new clip?
November 15, 2024 at 3:05 pm #472515vidmarc
ParticipantNovember 15, 2024 at 3:20 pm #472516electrofix
Moderatoryou need to cut the cable back and put a new terminal on
you have to cut back till you find clean wire or it will burn out in weeks
November 15, 2024 at 3:28 pm #472517vidmarc
ParticipantWhere can I find heat-resistant terminal clips – and a crimper?
November 15, 2024 at 3:40 pm #472518vidmarc
ParticipantAnd a little extra cable, so I can crimp them together and make it a bit longer.
November 15, 2024 at 5:43 pm #472519vidmarc
ParticipantI took the back off, and was able to feed some more of the cable through. 🙂
November 15, 2024 at 9:05 pm #472520electrofix
Moderatorcrimper is here
https://www.ebay.co.uk/itm/156441424…Bk9SR6KtwpnmZA
then you need terminals like this
November 18, 2024 at 5:48 pm #472521vidmarc
ParticipantOven working perfectly again. Thanks for your help. 🙂
July 21, 2025 at 3:10 pm #472522vidmarc
ParticipantI put another new element in last October (2024) and it’s been working fine until today. Was cooking some croissants and the the wall mounted fusebox oven circuit fuse blew. I’ve looked at the element and I can’t see any signs that this was the cause. I’ve also opened the back up and can’t see any obvious signs of what could have happened.
I’m now worried about switching the oven circuit fusebox back on. Any suggestions? Thanks.
July 21, 2025 at 7:07 pm #472523electrofix
Moderatoryou say fuse blew but you actually mean it tripped
there are 2 kinds of trips
one measures earth faults and you can turn that on and try it as often as you like as it does not go bang
the other measures current overload and that can cause damagewhat i am after is what blew ?
July 22, 2025 at 9:16 am #472524vidmarc
ParticipantThe main fusebox blew (with a bang) which feeds the oven. I checked the oven and couldn’t see any obvious signs of what caused the fuse to blow.
July 22, 2025 at 6:24 pm #472525electrofix
Moderatorwhat was on at the time is normally a good place to start
and does this fuse box feed anything else as anything it feeds is suspect
was it the rcd that blew ( the one with a test button )
