Neff S5943X2GB Integrated washer being a pain!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Neff S5943X2GB Integrated washer being a pain!
Viewing 15 posts - 1 through 15 (of 38 total)
  • #79132
    alexanderfoti
    Hi all
    I have a Neff S5943X2GB in a new flat I have just moved into.
    It cleans pretty badly and the dishes come out wet most of the time at the end of the cycle.
    Additionally the hottest cycle takes 3-4 hours!
    At the end of the whole thing the dishes still arent clean. I have cleaned the rotating arms and also cleaned the filters at the bottom. It has a cold water feed into the system.
    Any ideas? Thanks in advance!
    #408052
    Re: Neff S5943X2GB Integrated washer being a pain!
    Is it heating at all?
    #408053
    alexanderfoti
    The dishes are vaugely warm at the end, not stone cold but no steam etc.
    #408054
    Then it isn’t heating for starters. Time to drag it out and do some tests. Start with the heater. OR call out a local independent repairer to take a look. 💡
    #408055
    alexanderfoti
    Im pretty handy with a multimeter. Happy to do some testing. A bit of guidance on locating the heater?
    #408056
    Right hand side panel off.
    #408057
    alexanderfoti
    Will get it done shortly. Thanks!
    #408058
    alexanderfoti
    OK right hand side panel is off.
    #408059
    alexanderfoti
    and I am presented with:
    #408060
    Now get handy with your multimeter. 😉
    #408061
    alexanderfoti
    OK, 24 ohms between the elements.
    The black switch device is infinite or open circuit, but im not sure what its meant to measure?
    #408062
    alexanderfoti
    Ok, a quick read seems to indicate that the microswitch is a water presence switch, so I assume without water in it, it wont show closed.
    #408063
    alexanderfoti
    With the water presence switch bridged it still doesnt heat so that rules out a faulty switch
    #408064
    alexanderfoti
    Right, the NTC and temp switch unit on the top of the heater, the right hand pin (with the smaller diameter wires) is showing open circuit. The ticker red wires are 0 ohms.
    Does that mean that is faulty?
    #408065
    alexanderfoti
    Have also just checked the PCB for cold solder joints/damage.
    All looks AOK on that side
