Neff S5943X2GB Integrated washer being a pain!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Neff S5943X2GB Integrated washer being a pain!
Viewing 15 posts - 16 through 30 (of 38 total)
  • #408066
    alexanderfoti
    Re: Neff S5943X2GB Integrated washer being a pain!
    Can anybody confirm whether that the second 2 pins on the NTC should read anything?
    I will get a replacement sensor but just want to be sure.
    EDIT: with the conector disconnected I get 68K Ohms from the sensor.
    I have monitored the element pins whilst It was running and I never see any voltage on them.
    Any idea where to go from here.
    #408067
    alexanderfoti
    Just to tidy up this thread.
    I have bridged the level sensor with still no heat.
    I have bridged the NTC with a 48K resistor. Still no heat.
    I have no voltage on the heater pins when the heater should be running. If I have ruled out the water level switch, the NTC and thermostat and the element itself then it must be wiring or PCB?
    I have checked the PCB for cold joints, but maybe the relay on the board is broken?
    #408068
    alexanderfoti
    I have just run another test run. It does get maringally warm. The water isnt stone cold, which makes me thing the heater is working to a certain extent?
    #408069
    alexanderfoti wrote:I have checked the PCB for cold joints, but maybe the relay on the board is broken?
    A common failing for sure. :tup:
    #408070
    alexanderfoti
    Just did another test, with the multimeters on the heating element, and its getting 240 volts…. im completely stumped now.
    #408071
    When it washes is there plenty of water sloshing around in there? And do the spray arms alternate (switch from top spray to bottom spray) every 55 seconds?
    #408072
    alexanderfoti
    Large amounts, both spray arms appear to alternate correctly.
    #408073
    alexanderfoti
    Also to confirm what I have already done:
    Heater element has a resistance of 23 ohms.
    The pressure switch works properly
    The NTC/Thermostat at the top measures 0 ohms (closed) and 50Kohms at room temperature.
    The PCB shows no burnt traces or dry solder joints.
    I have ran the machine with a multimeter on the heating element and do see 230 volts for a bit. I didnt wait to see how long for however.
    #408074
    alexanderfoti wrote:I have ran the machine with a multimeter on the heating element and do see 230 volts for a bit.
    Would advise crock clips to enable a longer test period. 💡
    #408075
    alexanderfoti
    How long should I watch it after starting, its pretty boring 🙂
    #408076
    On a ‘Quick Wash’ cycle the heater will come on within 10 mins or so (IIRC) and remain on for a good 20 mins. ( or there abouts). So crock clips the best/safest test method during that time obviously. 😀
    #408077
    alexanderfoti
    Indeed, no problem. I will give it a look.
    #408078
    alexanderfoti
    New info – I sat and watched it, it turns on, drains for 20 seconds, I hear relays clicking and it fills with (some) water, where it then attempts the rinse. It is barely dribbling out of the spray arms. If I fill it then then close it it rinses properly, then does the same thing on the heated wash section.
    If I then pour a couple of liters of water into the dishwasher and close it, it washes properly and heats properly as well.
    Is there a float sensor that needs adjusting? All water inlet screens are clear. It is pumping some water in when needed, just not enough it appears.
    #408079
    The normal water level should just cover the salt container collar (not the salt cap). From the sounds of it the problem is with the fill process and you need to observe and report back as to what happens? (left hand side panel removed)
    #408080
    alexanderfoti
    Aha, no I dont see a water level at the salt container when I open it at all.
    I will take the left hand panel off and let you know what happens.
