New Machine… 1
Viewing 15 posts - 31 through 45 (of 74 total)
  • #207266
    derbyhoppy
    As Ken says, we went for the top specification would could and the machine at Sibson was the base ISE machine. The dishwasher was not, the fully free standing version which more closely matched the washer was not available so they supplied the semi integrated stainless version.
    John
    #207267
    Re: New Machine… 1
    Is it possible to set the temperature control both above and below its programme default settings?
    #207268
    Until we test it I can’t say for sure.
    Re: New Machine… 1
    Are there any machines on the market on which you can set the temp above the default setting? Surely such a feature would allow someone to boil their woollens.
    gegsy
    Re: New Machine… 1
    Usually, like you said Jim, if you select a 90 wash you would be able to select that temp and below. Likewise on say a 60 you would be able to select that temp below but not above, as it would be pointless. It also guards against little fingers adjusting the temperature during a wash.
    Will have a play with it as Sean has it in the workshop 🙂
    Re: New Machine… 1
    Oooh Matron, 😯 😆
    #207272
    gegsy
    Re: New Machine… 1
    iadom wrote:
    Oooh Matron, 😯 😆
    Its never too early for a Carry On moment is it Jim 😆
    kwatt wrote:you’d drop AAA and get AAB and lose a couple of thousand RPM on spin.
    Good grief – just how fast does it spin?
    1600rpm
    Re: New Machine… 1
    Correct me if I am wrong but the machine we saw at Sibson had a 1400 spin speed. 😕 However, losing a ‘couple of thousand RPM’ would make go into reverse. 😆
    Samples. 😉
    Re: New Machine… 1
    So, correct Chris & myself, if a machine doing 1600 RPM loses a ‘couple of thousand RPM’ it would be doing -400 RPM, is that not going against the laws of physics. :rolls: 😉 😆
    gegsy
    Re: New Machine… 1
    :stir: :study:
    #207279
    No you’re just picking me up on a silly mistake. 😉
    Re: New Machine… 1
    Heh, heh – the clothes would be getting wetter as they sucked water back in……..
    Cheer up, Ken 😀
    :p45:
